Hello, This is my first post.I have been trying to rip some PAL video files into region free. I've used DVD Fab 10 and DVD Shrink with no luck. Output files are still PAL. I have a Sony BDP S380 and I can't hack it to play region free. This DVD was stolen from me and I miss it. Any help would be greatly appreciated. Thanks
Making something region-free doesn't automatically also convert it from PAL to NTSC. If you want it to play as a DVD on your NTSC DVD player, you have to both remove the region coding (all decrypters do that) and then convert the DVD to NTSC. If you don't understand the difference between the two, then read What Is DVD. Scroll down to the 'Technical Info' and note the differing resolutions.
Try AvsToDVD. -
The region code on a DVD is just one number on the disc. Licensed players check that number to determine if they are allowed to play the DVD. If the region code matches the players region code it plays the disc, other wise it doesn't. The region code has nothing to do with PAL or NTSC encoding. In fact, some regions encompass countries that are PAL and NTSC.
PAL and NTSC are properties of the video data on the discs. PAL is 720x576 at 25 fps, NTSC is 720x480 at 29.97 fps. In the Europe most players can deal with both PAL and NTSC video. Unfortunately, in the USA many players cannot handle PAL.
Ripping Interlaced Pal dvd HELP
By pdox220 in forum DVD RippingReplies: 9Last Post: 14th Aug 2017, 01:17 -
Ripping Reg 2 PAL DVD's?
By tkmops in forum DVD RippingReplies: 21Last Post: 13th Oct 2016, 06:51 -
ripping a PAL DVD snippet to MacBookAir for an iMovie
By MsCurve in forum Newbie / General discussionsReplies: 2Last Post: 5th May 2015, 11:39 -
Audio high pitched when ripping: PAL DVD in PAL region
By BrissyGuy in forum AudioReplies: 19Last Post: 30th Mar 2015, 06:16 -
Ripping NTSC DVD that was originally filmed as PAL
By chris1379 in forum DVD RippingReplies: 2Last Post: 19th Jan 2014, 22:03
