Is it possible to take out HEVC from video files so I can play them on my WDTVLIVE? John
you have to convert them using another CoDec, like h264 etc..
use your favorite video conversion software, output to mp4 container using the codec of your choice
the file will be a little larger for the same resolution and same quality
HEVC aka h265 ? is the latest and greatest ? popular codec offering more compression aka smaller file size
but takes more processor power to unpack and display
and many hardware boxes, can't process it, but you can watch it on your PC,Last edited by theewizard; 31st Mar 2017 at 01:52.
Video conversion software like freemake. If there is a better one can you give some advice on that? Is there a converter that is better?? Quite possibility a free one?John
yes I know, wdtvlive's don't like h.265, and only some of h.264.
well, I suppose you could convert your file to mpeg4/avc (h.264) in a .mp4 container file (assuming the audio is compatible and doesn't need transcoding too, and it is progressive frames not interlaced frames) which is compatible with wdtvlive, by downloading ffmpeg and using a DOS command like
ffmpeg.exe -i "input_file.mkv" -threads 0 -map_metadata -1 -c:a copy -c:v h264 -preset slow -profile:v high -level 4.1 -crf 20 -coder 0 -movflags +faststart -y "output_file.mp4"
ffmpeg.exe -i "input_file.mkv" -threads 0 -map_metadata -1 -c:a libmp3lame -ab 256k -c:v h264 -preset slow -profile:v high -level 4.1 -crf 20 -coder 0 -movflags +faststart -y "output_file.mp4" -
Or! Replace your WDTV Live with something a tad newer like the Popcorn A-500 then you can play H265 aka HEVC files - sadly not a free option
Which player would you recommend for playing files HEVC - H265 - DivX265
By Marchand in forum Software PlayingReplies: 6Last Post: 16th Feb 2015, 10:42 -
HEVC Video Resolution in SUPER
By SuperAlex in forum Video ConversionReplies: 3Last Post: 28th Apr 2014, 04:21 -
muxing audio and video from hevc encode to final video container
By vhelp in forum AudioReplies: 24Last Post: 21st Nov 2013, 10:31 -
what are the minimum support files needed for hevc videos to mp4 ?
By vhelp in forum Video ConversionReplies: 2Last Post: 3rd Nov 2013, 13:44 -
theX.265 (a free HEVC) codec. Have you ever tried that HEVC encoder? (HELP)
By Stears555 in forum Video ConversionReplies: 41Last Post: 16th Sep 2013, 11:15
