Hi, I just register to the forum, I've been trying for days to encode the first episode of Flip Flappers but I keep getting this weird artifacts in the dark scenes so I downloaded a release of a anime encoding group( Good Job Media), in their encode of the first episode they almost got rid of all these artifacts, I wanted to know which x264 setting I have to tweak to get rid of the artifacts.
In the BDMV these artifacts are also present but are less noticeable.
BDMV:
Full size:https://forum.videohelp.com/images/imgfiles/Z4grRoi.png
My encode:
Full size:https://forum.videohelp.com/images/imgfiles/uUjpNvC.png
My settings:8-bit/Chroma subsampling: 4:2:0
cabac=1 / ref=16 / deblock=1:-1:-2 / analyse=0x3:0x133 / me=tesa / subme=11 / psy=1 / psy_rd=0.70:0.00 / mixed_ref=1 / me_range=32 / chroma_me=1 / trellis=2 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=0 / chroma_qp_offset=-2 / threads=6 / lookahead_threads=1 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=16 / b_pyramid=2 / b_adapt=2 / b_bias=0 / direct=3 / weightb=1 / open_gop=0 / weightp=2 / keyint=240 / keyint_min=24 / scenecut=40 / intra_refresh=0 / rc_lookahead=60 / rc=crf / mbtree=1 / crf=15.0 / qcomp=0.60 / qpmin=0 / qpmax=69 / qpstep=4 / vbv_maxrate=300000 / vbv_bufsize=300000 / crf_max=0.0 / nal_hrd=none / filler=0 / ip_ratio=1.40 / aq=1:1.00
Good Job Media encode:
Full size:https://forum.videohelp.com/images/imgfiles/Hl1Jx3G.png
Good Job Media settings:10-bit/Chroma subsampling: 4:4:4
cabac=1 / ref=16 / deblock=1:-1:-2 / analyse=0x3:0x133 / me=tesa / subme=10 / psy=1 / fade_compensate=0.70 / psy_rd=0.70:0.00 / mixed_ref=1 / me_range=32 / chroma_me=1 / trellis=2 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=0 / chroma_qp_offset=-1 / threads=9 / lookahead_threads=2 / sliced_threads=0 / nr=0 / decimate=0 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / fgo=0 / bframes=16 / b_pyramid=2 / b_adapt=2 / b_bias=0 / direct=3 / weightb=1 / open_gop=0 / weightp=2 / keyint=250 / keyint_min=23 / scenecut=40 / intra_refresh=0 / rc_lookahead=80 / rc=crf / mbtree=1 / crf=16.5000 / qcomp=0.68 / qpmin=0:0:0 / qpmax=81:81:81 / qpstep=4 / ip_ratio=1.40 / aq=3:0.85 / aq-sensitivity=10.00 / aq-factor=1.00:1.00:1.00 / aq2=0 / aq3=0
I'm using Handbrake 1.0.3 64-bit
They are using a different x264 build with the fade compensate patch, and aq3 patch. But you can't drop in and replace the binary with handbrake, you'd have to use something other than handbrake like a custom x264cli directly
10bit encoding also helps alot with banding/blocking along gradients. You're using 8bit. Maybe one of the handbrake nightly builds offers 10bit, not sure. You're probably better of using something else if it doesn't
Reduce Quilting artifacts - SVHS to DV
By Topsy in forum RestorationReplies: 6Last Post: 14th Jan 2017, 08:34 -
Should i encode anime DVDrips in x265 or stick to x264?
By zanzar in forum Newbie / General discussionsReplies: 1Last Post: 13th Sep 2016, 14:37 -
Help - Best way to encode anime and improve image quality
By yusuke10 in forum Video ConversionReplies: 7Last Post: 9th Mar 2016, 02:23 -
Cant encode this scene in x264 without blocking
By premiumcapture in forum Video ConversionReplies: 15Last Post: 29th Mar 2015, 10:13 -
Blocking a user?
By Paxmilitaris in forum Newbie / General discussionsReplies: 3Last Post: 14th Jan 2015, 15:26
