Results 1 to 18 of 18
    Aug 2001
    Chicago IL
    Hey guys, I am wondering which tmpgenc settings to use to get high quality svcds using only two discs. I always end up with a 2 gb mpeg 2 file that has to be split into 3 discs when I encode. I am only asking because I downloaded The Deep End from the net, already in vcd format, and it is an svcd, perfect quality, and only two discs. I loaded the mpeg from the cd to tmpgenc, and noted the settings, but I still came out with a bigger mpeg 2 file, and it was a shorter movie (The Deep End is over two Hours). Can anyone help me with this?
  2. ....Of course we are talking about 2 pass VBR and High quality motion detection, 224 Kb/s audio settings.
    Now....
    First step, get the total frame rate of your film.
    Divide it by two, and play with the TMPGenc settings of the wizard, to find out which mazimum kb/s can be used to sotreyour SVCD onto your 80' CD.
    You should also know if your CDwriter does support overburning and how much (90' ?, 99' ??), to exploit the feature to store more data i.e. to use a better byte rate.
    In this case also try if your standalone player does play overburned SVCD..
    That's the maximum you can get from a two discs SVCD, whatever is the lenght of the film.
    Giuliano
    Aug 2001
    Chicago IL
    Thanks for the reply. I've tried to use 2pass vbr, and the encoding screen goes blank, and when I cancel encoding, it erases itself. When I put it back to constant bitrate, the movie shows in the screen again. Anyone know why?
  4. Yes, because thats how 2pass VBR works, the first %50, the encoding preview will be blank, the 2nd %50 it will be normal. 2pass VBR 'analyses' the movie in the first %50, and encodes it in the 2nd. Of course this will mean that it takes twice as long to encode, as the same movie in CBR, or 1 Pass VBR (CQ/MVBR) but two pass VBR is definetaly what you should be using if you want high quality VCD's on two disks.
    Aug 2001
    Chicago IL
    Ah ha!! Thanks for the info Douglesh! I will try that method right now.
  6. Personally, i think CCE's CBR @ 2000KBITS gives a very good result. You can fit about 100 minutes on 2 (700) cd's at 2000. As for CCE's One/Multipass VBR, i havent made a single working video stream without errors from about 50 attempts.
    Aug 2001
    Chicago IL
    Hmm....Interesting....I will have to reinstall cce to try that way so I can compare picture resolutions. I like good resolution, I just don't want to swap 3 discs!! Two is bad enough.
    Aug 2001
    Chicago IL
    Another related question: I encoded Meet the Parents from Divx to Mpeg-2 with 2 pass VBR, Average bit rate: 2000kbs, maximum 2500kbs, and it came out to about 1.7 gigs. But I cannot split it using tmpgenc's Merge and Cut feature. The slider will not move. Any advice? Thanks.
  9. Use the BBMPEG its the best SVCD cutter.
    Aug 2001
    Chicago IL
    I'll try that....thanks for the tip
  11. You can split it, just not by moving the slider, you have to enter the value in seconds.
    Aug 2001
    Chicago IL
    Why didn't I think of that? Thanks Douglesh...
  13. Ugg...the MPEG Tools in TMPGEnc are sometimes buggy, beware. BBMPEG is pretty solid.
  14. Member DVWannaB's Avatar
    Dec 2001
    While we are on it. How do you split a movie using BBMPEG? Thanks.
    Sep 2001
    N/A
    cce avg 1700 bitrate.
    Thats all.
    Baker
    Aug 2001
    Chicago IL
    Hey, I am trying to encode using cce, and it gives me error message "couldn't find appropriate video codec for 'div 4' ". What's going on?
  17. It probably means you have only got the decoder installed. Try to find DivX 3.11 alpha (the best divX codec) somewhere on the net, it isnt too hard. Download & install, problem solved.
  18. Member
    Aug 2001
    Chicago IL
    You the man Douglesh. Thanks again.
