Hi,
I have a 2.2Gb mp4 video file which I cut to 5 files each of 500MB by using MyMP4BoxGUI. There were no errors with the cutting.
But I am not able to play each of the cut files using Windows Media Play. The original 2.2Gb file plays ok.
The error from WMP is :
Windows Media Player cannot play the file. The Player might not support the file type or might not support the codec that was used to compress the file.
Can some help to explain if I have done something wrong?
Try to replace the mp4box that comes with MyMP4BoxGUI with an up-to-date version.
Thanks sneaker for the reply. The version I am using is 0.6.0.6. After splitting, it's the first file that cannot be played. The rest are ok.
Thanks hech54 for your reply. Unfortunately, the orgnaisation only allows the default WMP and no other third party players. I tried on MPC and it works. It's only the first file that cannot be played.
Unable to play mp4 video file
By thegodlygod in forum EditingReplies: 3Last Post: 18th Feb 2016, 04:10 -
Unable to play recorded video in laptop while it plays in setup box.
By sant527 in forum Newbie / General discussionsReplies: 2Last Post: 15th Dec 2015, 16:31 -
Unable to Play BluRay
By Elderlore in forum Newbie / General discussionsReplies: 8Last Post: 22nd Nov 2015, 12:20 -
Unable to play converted videos to avi or mp4 on my video player
By tsvr1890 in forum Video ConversionReplies: 9Last Post: 11th Nov 2014, 12:17 -
unable to play recovered video files
By dingus in forum Newbie / General discussionsReplies: 13Last Post: 29th Aug 2013, 20:37
