is there a dvdfab x86 version because i keep getting when i install the latest version a runtime error and when i open dvdfab after installing it get the same runtime error the computer is a windows 32-bit
im guessing the new version can only work with 64-bit? and i really don't want to use an older version
The installer is for both 32bit and 64bit. It should install the correct one for your OS.
Can you give some more information?
Windows version?
Screenshot of the error?
Did you run the installer "As Administrator" or just double-click it?Do or do not. There is no "try." - Yoda -
turned out my video card drivers needed to be updated but i have a problem my old computer where the motherboard died i took the parts from that computer and put them in another computer that has a faster cpu the computer has 4gb of ram and faster dvd drive so on my old computer to rip a dvd to mkv would take around 15mins on average depending on how long the movie is so why is this computer ripping so slow it says it will take 2hrs
is it because im using a newer version on my old computer i was using a version from 2014
Not sure what could be causing your slow-down. I've been using DVDfab for years, and different computers have been slightly faster or slower, but I've never had one that has taken more than a half hour, even for a fully packed dual-layer DVD. The version of the program hasn't made any noticeable difference in rip speed for me. So if yours is taking two hours, maybe you still have other hardware drivers that need to be updated.
Cannot rip TV shows with handbrake x86 or x64 with libdvdcss
By Yanta in forum DVD RippingReplies: 2Last Post: 15th Jan 2015, 03:54 -
DVDFab
By agtjones in forum AudioReplies: 6Last Post: 27th Feb 2014, 16:53 -
DVDFab Creator
By JohnnyBob in forum Video ConversionReplies: 34Last Post: 3rd Oct 2013, 09:00 -
DVDFab 8.2.2.6/9.0.2.2
By tarzan54 in forum DVD RippingReplies: 6Last Post: 23rd Jan 2013, 20:16 -
Do I need to install LAME ACM x86 and x64?
By gOdiSOnyOuRsIDe in forum Software PlayingReplies: 6Last Post: 21st Jun 2012, 22:17
