Could somebody share the fra.dic file ? (preferably mediafire) Every time I try to download it via subtitle edit I get an unhandled exception. Spansih and Japanese download fine
I pasted the exception text below.
See the end of this message for details on invoking
just-in-time (JIT) debugging instead of this dialog box.
************** Exception Text **************
System.IO.InvalidDataException: Found invalid data while decoding.
at System.IO.Compression.ZipExtractor.Open(Stream stream)
at Nikse.SubtitleEdit.Forms.GetDictionaries.wc_Downlo adDataCompleted(Object sender, DownloadDataCompletedEventArgs e)
at System.Net.WebClient.OnDownloadDataCompleted(Downl oadDataCompletedEventArgs e)
************** Loaded Assemblies **************
mscorlib
Assembly Version: 4.0.0.0
Win32 Version: 4.6.1637.0 built by: NETFXREL3STAGE
CodeBase: file:///C:/Windows/Microsoft.NET/Framework64/v4.0.30319/mscorlib.dll
SubtitleEdit
Assembly Version: 3.4.6.544
Win32 Version: 3.4.6.544
CodeBase: file:///C:/Program%20Files%20(x86)/Subtitle%20Edit/SubtitleEdit.exe
System.Core
Win32 Version: 4.6.1638.0 built by: NETFXREL3STAGE
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Core/v4.0_4.0.0.0__b77a5c561934e089/System.Core.dll
System
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System/v4.0_4.0.0.0__b77a5c561934e089/System.dll
System.Windows.Forms
Win32 Version: 4.6.1586.0 built by: NETFXREL2
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Windows.Forms/v4.0_4.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
System.Drawing
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Drawing/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
System.Configuration
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Configuration/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
System.Xml
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Xml/v4.0_4.0.0.0__b77a5c561934e089/System.Xml.dll
************** JIT Debugging **************
To enable just-in-time (JIT) debugging, the .config file for this
application or computer (machine.config) must have the
jitDebugging value set in the system.windows.forms section.
The application must also be compiled with debugging
enabled.
For example:
<configuration>
<system.windows.forms jitDebugging="true" />
</configuration>
When JIT debugging is enabled, any unhandled exception
will be sent to the JIT debugger registered on the computer
rather than be handled by this dialog box.
why yes that is exactly what I was looking for you. you're a lifesaver. thank you so much! i shall learn french!
Subtitle edit
By Costantinil in forum SubtitleReplies: 20Last Post: 28th Jul 2023, 09:41 -
OCR a video with Google's OCR
By ThePi7on in forum SubtitleReplies: 0Last Post: 6th Mar 2017, 11:38 -
subtitle edit
By mrgiannis in forum SubtitleReplies: 2Last Post: 11th Feb 2016, 11:50 -
Bad french fonts in Subtitle Workshop
By Patapin in forum SubtitleReplies: 7Last Post: 19th Aug 2013, 12:12 -
No german option in subtitle ocr after installing trainer
By chatumao in forum SubtitleReplies: 9Last Post: 6th Jan 2013, 20:17
