Hi,
One of my video files is in AVI format. When I run it on any of a few windows applications, the film's subtitles are partially cut/ I can see its upper part, but not its lower part.
Is there away to adjust the file for normal view?
Here're the details of the file as shown by mediainfo:
General
Complete name : M:\Downloads\לאהוב את סופיה.avi
Format : AVI
File size : 730 MiB
Duration : 1 h 10 min
Overall bit rate : 1 442 kb/s
Writing application : VirtualDubMod 1.5.10.1 (build 2366/release)
Writing library : VirtualDubMod build 2366/release
Video
Format : MPEG-4 Visual
Format profile : Advanced Simple@L5
Format settings, BVOP : 2
Format settings, QPel : No
Format settings, GMC : No warppoints
Format settings, Matrix : Default (H.263)
Muxing mode : Packed bitstream
Codec ID : XVID
Codec ID/Hint : XviD
Bit rate : 1 177 kb/s
Width : 688 pixels
Height : 512 pixels
Display aspect ratio : 4:3
Frame rate : 25.000 FPS
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Compression mode : Lossy
Bits/(Pixel*Frame) : 0.134
Stream size : 596 MiB (82%)
Writing library : XviD 1.2.1 (UTC 2008-12-04)
Audio
Format : MPEG Audio
Format version : Version 1
Format profile : Layer 3
Codec ID : 55
Codec ID/Hint : MP3
Bit rate mode : Constant
Bit rate : 256 kb/s
Channel(s) : 2 channels
Sampling rate : 44.1 kHz
Stream size : 129 MiB (18%)
Alignment : Split accross interleaves
Interleave, duration : 40 ms (1.00 video frame)
Interleave, preload duration : 500 ms
Results 1 to 9 of 9
Thanks, Sneaker.
Yes' the subtitles are hardcoded. I suspected that the format of the video somehow extends the limits of the screen. I found no way to test it. -
I doubt it. Probably the subtitles were in some kind of image format, e.g. at 720x576 pixels resolution. When re-encoding the file the encoder resized the video to 688x512 pixels but didn't move subtitles up. So the bottom 64 pixels (~=10% of picture) of the subtitles were cut off. Does that fit with what you are seeing?
688 x 512 is an odd size for a video.
It sounds like either
A) it was originally a larger image, and was cropped after the subtitles were coded into it, or
B) as sneaker suggested, it was resized down to 688x512, but the subtitle location was not adjusted accordingly.
If the subtitles were already hard-coded in the file when you downloaded it, then there's not a whole lot you can do about it, other than trying to locate a different version of the video.Do or do not. There is no "try." - Yoda -
Try re-rendering it again at 720x576, and make sure the resolution settings are the same. This is a standard SD format so it should show up in your render settings, or if not do a custom setting to match. Do a 30 sec test rather than the whole movie again just to make sure your happy with the output [emoji106]
Sent from my iPhone using Tapatalk -
Help needed! Trying to add subtitles & convert to audio and cut
By crisjarvis89 in forum SubtitleReplies: 1Last Post: 7th Apr 2016, 09:18 -
Cut Video and subtitles
By Tylerr in forum EditingReplies: 10Last Post: 9th Oct 2015, 03:28 -
Cut off subtitles on DVDFab 9
By acircleda in forum SubtitleReplies: 2Last Post: 11th Aug 2014, 22:37 -
Cut part from video and cut subtitles as well
By aapje in forum Video ConversionReplies: 7Last Post: 8th Feb 2014, 11:11 -
Looking for command line tools to cut subtitles,..
By Selur in forum SubtitleReplies: 0Last Post: 6th Jul 2013, 10:58
