I have the above Blue Ray Reader. When plugged into a pc (Windows 10) said reader is detected in Explorer as BD-RE Drive. However a BlueRay disc is not read "Please Insert Disk". I'm trying to examine the folder structure.
I contacted a friend who has a Sony Vaio (Windows 10) using the built in drive + Blue ray sticker but same problem.
Any suggestions what we're doing wrong and how to see the disk.
Results 1 to 11 of 11
Here is one fix found here: https://answers.microsoft.com/en-us/windows/forum/windows_10-hardware/my-samsung-blu-r...d3c7971?auth=1
Try the following:
Right-click the Start button > Command Prompt (Admin)
Then, at the command prompt type the following ( you can copy and paste) and press "Enter":
reg.exe add "HKLM\System\CurrentControlSet\Services\atapi\Cont roller0" /f /v EnumDevice1 /t REG_DWORD /d 0x00000001
Restart the computer.
Please let us know if this works.Extraordinary claims require extraordinary evidence -Carl Sagan -
Hi Thanks for your quick reply. The drive is still being detected but a Blue Ray disk is steadfastly being refused to be read, "Please Insert a disk".
What kind of BlueRay disc is it ?? Movie, audio disc, game disc or ??
Do you have another bluray disc you can try ??
Also what region is the disc and what region is your drive ?? -
Try right clicking on the drive - properties - hardware - slect your bluray drive - properties - dvd/bluray region and change it to region 2 and Region B
Thanks for your reply. I'm not sure how to do that. If you select a country (UK for me) it populates the box with Region 2. How would I set it for 2 and B ? I would need the exact syntax ie Region 2 and Region B or Regions 2, B The reason I ask is that I have already changed this and am running out of changes.
If your drive is already set to region 2 and no disc
Still won't play then I'd say you have a defective drive. -
I should add that it works fine with a Standard Definition DVD if that is significant.
Samsung writer won't reinstall, not supported by Samsung
By blacktooth in forum DVD & Blu-ray WritersReplies: 4Last Post: 11th Jan 2017, 22:47 -
Samsung BD 8509 S
By Steptoe8949 in forum Newbie / General discussionsReplies: 6Last Post: 19th Nov 2015, 19:30 -
Reset of Video on Harman Kardon DVD 506 Player.
By keithsloan52 in forum DVD & Blu-ray PlayersReplies: 4Last Post: 28th Mar 2014, 16:00 -
Samsung 3d subtitles
By fits79 in forum SubtitleReplies: 29Last Post: 6th Mar 2014, 16:30 -
Samsung BD-E8500N
By hnl in forum DVD & Blu-ray RecordersReplies: 3Last Post: 20th Apr 2012, 17:23
