Hey you guys! I'm having a hell of a problem!![]()
All the vcds I make end up having the same f*cking problem! When there's only 20min left to the end of it, it starts popping some stuff on the screen, the image starts to disappear and, all of a sudden, the vcd just won't play anymore. Do you know what's happening?
I always convert the mpgs to compatible using TMPEnc and I burn the cds using Easy CD Creator 5.0 and my burner is a LG 8x4x32
Can you help me??
PLEEEEEEEEEEEEEEASE!
Thank you
It sounds like you are overburning your CD's, and your DVD player doens't want to or won't support the overburn. I had a similiar problem with my Sony DVD player, I quit trying to overburn the CD's and I never had that problem again. Also, EZ CD Creator has been reported to have problems making a 'good' VCD. I used to use version 4 and I never had any problems. But I didn't upgrade to version 5 because of all the reported problems with VCD's.
Now I use VCD Easy, and it works great.
I hope this helps.
shiver24
New LG DVD Player not playing VCDs
By atlmallu in forum DVD & Blu-ray PlayersReplies: 15Last Post: 4th Dec 2010, 15:28 -
Avi(xvid) problems + dvd player
By sgbd in forum Video ConversionReplies: 1Last Post: 20th Nov 2010, 11:53 -
Connecting DVD player through HDMI: 2 Problems
By Markaveli in forum DVD & Blu-ray PlayersReplies: 10Last Post: 22nd Aug 2008, 06:40 -
[Help] Problems creating VCDs.
By scott274 in forum Newbie / General discussionsReplies: 77Last Post: 15th Jul 2008, 02:43 -
Insignia portable DVD player can't play VCDs
By Amuse in forum DVD & Blu-ray PlayersReplies: 3Last Post: 11th Nov 2007, 19:28
