I am trying to build graph to connect to this encoder (instead of using buggy supplied application for HD CaptureU3.0 Skydigital Inc Digital Audio Capture and Recorder)
But I can not find combination of filters that work
Anybody any idea?
sebus
Results 1 to 14 of 14
It seems to want to output some file. Can you connect it to the file writer or null renderer?
I can not connect Sky CapX USB 3.0 Capture to Sky Smart H264 Encoder in first place, so no worries YET what the output is...
Right click on the Capture output pin of the Sky CapX USB 3.0 Capture and select Render Pin. What do you get?
It does not ever render to the encoder, but it also does not render to any of the filters that show as compatible...
The point isn't to render to the encoder. The point is to build a graph that you can use as a guide. Then you can modify it by removing the screen renderer, routing to the encoder, etc.
Try removing the Video Renderer and connecting the output pin of the Color Space Converter to the input of the Sky Smart H264 Encoder.
Then you'll need to fix everything past the h264 decoder. You want to mux the audio and video together then output to a file. -
Another option might be to use ffmpeg with quicksync (or nvenc or libx264) , since it can access directshow devices
Check if your device is listed
http://ffmpeg.org/ffmpeg-devices.html#dshowCode:ffmpeg -list_devices true -f dshow -i dummy
I really have no idea how to create the required command for ffmpeg to get that going (either separate video/audio OR h264 video muxed with PCM audio - it must be PCM).Code:
C:\ffmpeg -list_devices true -f dshow -i dummy ffmpeg version N-84348-gdb7a05d Copyright (c) 2000-2017 the FFmpeg developers built with gcc 6.3.0 (GCC) configuration: --enable-gpl --enable-version3 --enable-cuda --enable-cuvid --e nable-d3d11va --enable-dxva2 --enable-libmfx --enable-nvenc --enable-avisynth -- enable-bzlib --enable-fontconfig --enable-frei0r --enable-gnutls --enable-iconv --enable-libass --enable-libbluray --enable-libbs2b --enable-libcaca --enable-li bfreetype --enable-libgme --enable-libgsm --enable-libilbc --enable-libmodplug - -enable-libmp3lame --enable-libopencore-amrnb --enable-libopencore-amrwb --enabl e-libopenh264 --enable-libopenjpeg --enable-libopus --enable-librtmp --enable-li bsnappy --enable-libsoxr --enable-libspeex --enable-libtheora --enable-libtwolam e --enable-libvidstab --enable-libvo-amrwbenc --enable-libvorbis --enable-libvpx --enable-libwavpack --enable-libwebp --enable-libx264 --enable-libx265 --enable -libxavs --enable-libxvid --enable-libzimg --enable-lzma --enable-zlib libavutil 55. 50.100 / 55. 50.100 libavcodec 57. 83.101 / 57. 83.101 libavformat 57. 66.105 / 57. 66.105 libavdevice 57. 3.100 / 57. 3.100 libavfilter 6. 78.100 / 6. 78.100 libswscale 4. 3.101 / 4. 3.101 libswresample 2. 4.100 / 2. 4.100 libpostproc 54. 2.100 / 54. 2.100 [dshow @ 000000000042a400] DirectShow video devices (some may be both video andaudio devices) [dshow @ 000000000042a400] "Sky Capx Component WebCam" [dshow @ 000000000042a400] Alternative name "@device_pnp_\\?\usb#vid_04b4&pid_00f2#5&3abda4e6&0&8#{65e8773d-8f56-11d0-a3b9-00a0c9223196}\{7cf2788a-6f04-47e6-ad82-9086319a0eaf}" [dshow @ 000000000042a400] "Sky CapX USB 3.0 Capture" [dshow @ 000000000042a400] Alternative name "@device_pnp_\\?\usb#vid_04b4&pid_00f2#5&3abda4e6&0&8#{65e8773d-8f56-11d0-a3b9-00a0c9223196}\{9b365890-165f-11d0-a195-0020afd156e4}" [dshow @ 000000000042a400] "Sky CapX HDMI WebCam" [dshow @ 000000000042a400] Alternative name "@device_pnp_\\?\usb#vid_04b4&pid_00f2#5&3abda4e6&0&8#{65e8773d-8f56-11d0-a3b9-00a0c9223196}\{e4e50471-166a-4261-b923-f6165bde81e1}" [dshow @ 000000000042a400] "HP HD Webcam [Fixed]" [dshow @ 000000000042a400] Alternative name "@device_pnp_\\?\usb#vid_05c8&pid_034b&mi_00#7&312ba39f&0&0000#{65e8773d-8f56-11d0-a3b9-00a0c9223196}\global" [dshow @ 000000000042a400] DirectShow audio devices [dshow @ 000000000042a400] "Audio In (Sky CapX USB 3.0 Driv" [dshow @ 000000000042a400] Alternative name "@device_cm_{33D9A762-90C8-11D0-BD43-00A0C911CE86}\Audio In (Sky CapX USB 3.0 Driv" [dshow @ 000000000042a400] "Internal Microphone Array (IDT " [dshow @ 000000000042a400] Alternative name "@device_cm_{33D9A762-90C8-11D0-BD43-00A0C911CE86}\Internal Microphone Array (IDT " [dshow @ 000000000042a400] "Stereo Mix (IDT High Definition" [dshow @ 000000000042a400] Alternative name "@device_cm_{33D9A762-90C8-11D0-BD43-00A0C911CE86}\Stereo Mix (IDT High Definition" dummy: Immediate exit requestedLast edited by sebus; 27th Mar 2017 at 03:39.
Is audio separate through mic or the device ? If both video and audio are through the device it will look something like this
Code:ffmpeg -f dshow -i video="Sky CapX USB 3.0 Capture":audio="Audio In (Sky CapX USB 3.0 Driv" -pix_fmt yuv420p -c:v h264_qsv -c:v pcm_s16le -f mkv output.mkv
Intel Quick Sync video samples
By vhelp in forum Video ConversionReplies: 23Last Post: 29th Mar 2017, 13:20 -
Xmedia-Intel Quick Sync
By jjis in forum EditingReplies: 3Last Post: 29th Jul 2016, 14:45 -
AVCHD rendering @60p w/ Intel Quick Sync Video problem - Vegas Pro 13
By Hambert in forum EditingReplies: 3Last Post: 19th Aug 2015, 11:44 -
BD Rebuilder - Does It Use Intel Quick Sync?
By hogger129 in forum Video ConversionReplies: 1Last Post: 27th Jul 2015, 16:53 -
Intel to release Quick Sync powered HEVC encoder soon?
By deadrats in forum Video ConversionReplies: 2Last Post: 3rd Jun 2014, 16:14
