Have this machine 6 - 7 years, a few years ago the digital TV tuner started going crazy.... just kept tuning channels continuously, couldn't get it to stop. Took it apart, cleaned, removed and reinserted a flat ribbon cable attached to the tuner circuit board. It worked for a while, then the tuner just got 'stuck' trying to do a simple channel scan....so it won't tune anything at all. Put it in the 'graveyard' closet in 2015, since I have many other recorders at my disposal.
After recently resurrecting a Philips 3506 back to working condition, I took the Toshiba out for inspection, seems that flat ribbon cable is probably shot. Looked on line for a replacement, can't seem to find the correct one. It's 20 - pin, about 3 inches long, with blue insertion plastic on both ends. There are numbers stamped on it that read "AWM 20624 80C 60V". I saw a few similar flat ribbon cables on line, but none seem to match. Anyone know where I can find one ?? I'd like to give the DR660 one more chance before I trash it.
Do you think the cable is corroded through? I don't see what else could happen to it just sitting there inside the machine. Sounds more like you have a problem with a component or trace on the tuner board.
Yeah, those contacts look pretty ratty. Maybe you could touch them up with a conductive paint pen. Also you may have a short between #2 and #3.
Toshiba D-VR4XSU HiFi Video Cassette Recorder & DVD Recorder / Player VCR
By fmitchelltx in forum Newbie / General discussionsReplies: 3Last Post: 9th Apr 2016, 22:40 -
DVD Recorder with VHS? Magnavox? Toshiba?
By quxote in forum DVD & Blu-ray RecordersReplies: 31Last Post: 2nd Dec 2015, 19:47 -
Toshiba DVR620 DVD/VHS Recorder, Black
By Jammers in forum DVD & Blu-ray RecordersReplies: 9Last Post: 30th Jun 2013, 00:06 -
Toshiba DR430KU DVD Recorder
By Frank-0-Video in forum DVD & Blu-ray RecordersReplies: 6Last Post: 15th Apr 2013, 21:33 -
Repair or replace Lite-On DD-A100GX DVD Recorder
By Henderson in forum DVD & Blu-ray RecordersReplies: 10Last Post: 19th Oct 2012, 06:11
