Hello!
I want to digitize a huge VHS collection.
I have a Mac Mini (Late 2012, 2.3GHz, i7, Quad-Core, 16 GB RAM) with firewire input.
I also have a high quality Panasonic SVHS recorder
and a Canopus ADVC-100 firewire capture device.
I could capture everything to DV format first, and convert to h264 later, but this would be space and time consuming.
QuickTime can do some sort of realtime h264 capturing, but it downsamples to 640x480, deinterlaces the footage and has a fixed low quality bitrate.
I would like to capture directly to h264 in full PAL resolution (without deinterlacing if possible).
Can you recommend a simple no frills capture software,
that will allow me to do realtime h264 capturing from my Canopus firewire device
in full PAL resolution with high quality?
Thanks in advance,
Aleksandar
Software Recommendation Please
By golfnut in forum Blu-ray RippingReplies: 5Last Post: 8th Aug 2015, 07:27 -
Beginner video editing software for Mac recommendation needed
By desidude in forum EditingReplies: 1Last Post: 27th Jul 2015, 02:53 -
Software recommendation for HD webcam/desktop capturing?
By Jon.G in forum Capturing and VCRReplies: 10Last Post: 2nd Mar 2015, 21:39 -
capture dv using firewire to h264, can it be done?
By pidro in forum Capturing and VCRReplies: 0Last Post: 1st Mar 2015, 22:41 -
Need a software recommendation
By PokerHandfull in forum Newbie / General discussionsReplies: 1Last Post: 2nd Oct 2013, 22:18
