    Jun 2005
    Norway
    Ok, so i have my vcr connected to my EasyCap device (it doesn't say which model no. on the easycap device) which in return is connected to my front usb3.0 port. I installed its drivers that followed with the cd belonging to the easycap, but somehow, it shows up as OEM Device in VirtualDub.. and i have no idea WHY.. any ideas on HOW i can fix this issue? Her is a video of my problem: https://www.youtube.com/watch?v=GKC4IuSswkk&feature=youtu.be
    EDIT: The picture and sound comes up nicely in the video edit program Honestech DVR 2.5 that was included with the easycap cd.
    I am running a Windows 7 64-bit.
  2. Member DB83's Avatar
    Jul 2007
    So is that 32 bit virtualdub or 64 bit ?
    And what happens if you select the WDM device rather than the OEM device ?
    So if you are using 64 bit virualdub then install the 32 bit version and try the WDM device.
