Hello!
I have Miami Vice set on Blu-Ray from Fabulous Films. Unfortunately they added to much contrast so i wanted to restore proper colors and in MPC-HC i go to
options-->shaders and chose 0-255 to 16-235.
Now colors are good, but when i want to make screenshot of some scene in proper colors MPC-HC saves my screenshot with original to much contrasted colors. How to fix it? Thank You for help!
You could try a screen shot with another program. Try windows snipping tool if you don't have another screen grab program.
Extraordinary claims require extraordinary evidence -Carl Sagan -
Can't fix it, per se. The screenshots are pulled from the stream before it's processed (your changes above). It's how the player works.
As noted above, try using a different tool to take screenshots.
And I wouldn't exactly say you are correcting the colors. You simply don't like or agree with the how the director wanted the film to look. All movies use varying/different color pallets.Google is your Friend -
Here is the screenshot from U.S version of Blu Ray (Milk Creek, correct colors)
Screenshot from U.K version (Fabulous Films)
when i change 0-255 to 16-235 colors are corrected and looks like from U.S Version.
First i tried in MPC-HC view-->renderer settings---> output range---> 16-235 but it doesn't work for me. The only way to change colors to 16-235 are shaders settings.Last edited by jimmy84; 24th Mar 2017 at 13:24.
Odd. Reviews and comparisons seem to indicate picture quality of both releases is excellent, with the Fabulous Films version actually being a bit better.
[MPC-HC (MPC-BE)] Can't change resizer: same output for each resizer
By rqqt in forum Newbie / General discussionsReplies: 2Last Post: 12th Aug 2016, 11:07 -
How to change the color space of output video in MPC-HC?
By Stears555 in forum Software PlayingReplies: 7Last Post: 16th Jul 2014, 07:56 -
Two MPC HC questions/problems
By SignedupGuest in forum Newbie / General discussionsReplies: 3Last Post: 2nd May 2014, 20:45 -
Newbie with avi and MPC-HC problems
By Lebanza in forum Newbie / General discussionsReplies: 2Last Post: 16th Apr 2013, 09:02 -
MPC - Video problems when going fullscreen?
By czeshire in forum Newbie / General discussionsReplies: 4Last Post: 2nd May 2012, 07:02
