Been using RipIt4Me for years with no problems. Tried to copy Iron Man 2 and the Video_TS file was 20GB from one dvd. Tried to use Movie Only Mode and when I played in dvd player there was no sound. When I view the Video_TS files on the computer the sound works fine. Why does sound not transfer in Movie Only Mode? Anyone have any guess? Thanks in advance.
				Results 1 to 9 of 9
	I will try that but since the sound works in the files on the computer before using Single Movie Mode with Roxio for the burning, is it possible to remove the unneeded files that make the original movie over 20GBs, so the movie and the bonus material would fit on one dvd? If I include a screen shot of the Video_TS files would any one know which files to remove to get to 4.7GB?
	It already fits on a single DVD. That's the added encryption to make it look like it's holding more than it really does in an attempt to defeat backing up your DVDs. Just do as october262 suggested first.
 It probably is on a dual layer DVD meaning up to maybe 8.5 GB. To fit on a single layer DVD you'll have to shrink it further. The best program for that is DVD Rebuilder, but there are lots of others (like DVD Shrink) which will produce output of varying quality.
	You probably want DVDFab HD Decrypter. Is that what you have? The first part of Baldrick's guide explains the process:
 https://forum.videohelp.com/threads/303110-How-to-easily-convert-DVD-to-high-quality-M...ing-free-tools
  Ulead Movie Factory 4 running on Windows 7 has no audio in edit modeBy Steeleye in forum Authoring (DVD)Replies: 1Last Post: 25th Dec 2014, 12:46
  Backing up Iron Man 3 and Avengers?By Diana (Cda) in forum DVD RippingReplies: 8Last Post: 11th Mar 2014, 06:44
  Renaming Various Audio Files in Batch Mode- MP3, Wav and Other Sound FormtsBy devilcoelhodog in forum AudioReplies: 3Last Post: 13th Dec 2013, 16:20
  What's your favorite spider-man movie?By johns0 in forum PollsReplies: 7Last Post: 5th Sep 2012, 15:14
  the best THE OFFICIAL VIDEO CONVERTER MOVIE MANBy tupidtunt2 in forum Video ConversionReplies: 6Last Post: 8th Jul 2012, 19:55
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
