please don't comment if I'm a c*t
Kindly I need to use fart.exe to change
intoCode:#reversibleColorMatrix#
How I have to do? thanksCode:colorMatrix(mode="Rec.709->Rec.601")
				Results 1 to 30 of 37
	It looks easy...Did you read about it at:
 http://fart-it.sourceforge.net
 Are u really a cat?'Do I look absolutely divine and regal, and yet at the same time very pretty and rather accessible?' - Queenie
 [Attachment 40986 - Click to enlarge]
 obviously
 because of that I'm not very practice with pc
	Replace "filename.avs" with the name of the file you want to change. And, of course, the usual path name syntax applies.Code:fart filename.avs #reversibleColorMatrix# colorMatrix(mode=\"Rec.709->Rec.601\")
	Maybe you should play in boxes only then and leave PC to a dog...
 [Attachment 40987 - Click to enlarge]'Do I look absolutely divine and regal, and yet at the same time very pretty and rather accessible?' - Queenie
	Cats converting video ... programs called "Fart" ...
 I can't tell if this place has changed massively in the seven years since I last logged on, or if it's business as usual just with different words.
 ...oh hey that actually looks quite useful, and it's not just linux-only either... *downloads Fart_win32.exe*
 miew-= She sez there's ants in the carpet, dirty little monsters! =-
 Back after a long time away, mainly because I now need to start making up vidcapped DVDRs for work and I haven't a clue where to start any more!
 [Attachment 40995 - Click to enlarge]
 thankssssss :d:d:d:d:d:d:d
	jagabo, for kindness: your line as "standalone" work. But when I try to insert is in a batch like this
 in the target .avs (!var!) I get this bad resultCode:@echo off if exist v:\automazioneclip\system\tempOut1.bat del v:\automazioneclip\system\tempOut1.bat setlocal enabledelayedexpansion c: cd\ cd volumes set "parentfolder=%CD%" for /r . %%g in (*.avs) do ( set "var=%%g" set var="c:\volumes!var:%parentfolder%=!" del out.txt echo V:\automazioneclip\system\fart.exe !var! "#VisualDeinterlaceApplicabile#" "bob().SelectEven()">>v:\automazioneclip\system\tempOut1.bat echo V:\automazioneclip\system\fart.exe !var! #reversibleColorMatrix# colorMatrix(mode=\"Rec.709->Rec.601\")>>v:\automazioneclip\system\tempOut1.bat ) v:\automazioneclip\system\tempOut1.bat del c:\volumes\tempOut1.bat
 this is missing of a ")". The correct result should beCode:colorMatrix(mode="Rec.709->Rec.601"
 maybe this happen because the entire line have the ">>" attached:Code:colorMatrix(mode="Rec.709->Rec.601")
 do you know if there is a way to resolve so that the final result isCode:echo V:\automazioneclip\system\fart.exe !var! #reversibleColorMatrix# colorMatrix(mode=\"Rec.709->Rec.601\")>>v:\automazioneclip\system\tempOut1.bat
 thankssCode:colorMatrix(mode="Rec.709->Rec.601")
 [Attachment 41000 - Click to enlarge]
 please help a poor cat  Last edited by marcorocchini; 21st Mar 2017 at 19:05.
	Code:echo V:\automazioneclip\system\fart.exe !var! #ColorMatrixReversibileDa709a601# colorMatrix(mode=\"Rec.709->Rec.601\"^)>>v:\automazioneclip\system\tempOut1.bat
	I knew a cat could encode video!!!
 [Attachment 41002 - Click to enlarge]'Do I look absolutely divine and regal, and yet at the same time very pretty and rather accessible?' - Queenie
	I see why I couldn't duplicate the problem. I was testing only at the two "echo" lines in a batch file (because it was too much trouble to modify the entire batch file). But it looks like the problem is that the close parenthesis on the second echo is being interpreted as the end of the "do" loop.
	parentheses are always a sort of trap in batch script one way or the other, better always call a function, just submerge it down a few levels if needed, it does not matter, batch keeps track of it, having hefty number of them, it actually clears things up not complicate them as one would think, those calling functions just get out of the way to the bottom of the script. It clears things up. ...But every calling function should always have an info what kind of file is that argument though, like in this case avisynth script
 Code:for /r . %%g in (*.avs) do call :temp_BAT "%%g" . . . :temp_BAT <avisynth script> set "var=%~1" set var="c:\volumes!var:%parentfolder%=!" if exist v:\automazioneclip\system\tempOut1.bat del v:\automazioneclip\system\tempOut1.bat V:\automazioneclip\system\fart.exe !var! #ColorMatrixReversibileDa709a601# colorMatrix(mode=\"Rec.709->Rec.601\"^) >>v:\automazioneclip\system\tempOut1.bat V:\automazioneclip\system\tempOut1.bat del c:\volumes\tempOut1.bat goto :eof
	jagabo please help: now I need to do the inverse operation
 if the inputfile.avs have a string callded:
 this string have to be replaced withCode:colorMatrix(mode="Rec.709->Rec.601") I have do many proof but I cannt find the solutionCode:#ColorMatrixReversibileDa709a601#
 how can I do? thankss
	Sorry, I deleted all the files I was testing with. Can't you just reverse the order of the two arguments?
	yes but strangely don't work.
 AH no, maybe it work
 please jagabo I wonder this: please consider this 3 .avs script
 script 1:
 script2:Code:LWLibavVideoSource("C:\Users\Administrator\Desktop\Nuova cartella (4)\IMX.MXF") crop(0,32,0,0) IResize(1920,1080)
 script3:Code:LWLibavVideoSource("C:\Users\Administrator\Desktop\Nuova cartella (4)\IMX.MXF") crop(0,32,0,0) colorMatrix(mode="Rec.601->Rec.709") colorMatrix(mode="Rec.709->Rec.601") IResize(1920,1080)
 Code:LWLibavVideoSource("C:\Users\Administrator\Desktop\Nuova cartella (4)\IMX.MXF") crop(0,32,0,0) colorMatrix(mode="Rec.601->Rec.709") IResize(1920,1080)
 Where IMX.MXF is s SD video file BT.601 colormatrix.
 In the 1 case it is loaded by svisynth "as is" (only SD-->HD resolution converted), but colormatrix keep 601
 In the 2 case, the colormatrix correction have to be the same charateristics of the 1 because was bring from 601 to 709 and successively from 709 to 601. So colormatrix remain 601
 In the 3 case, colormatrix is converted from 601 to 709
 I wonder, if I use the case 2 in place of 1, the cpu of my pc is it subjected to an increased workload respect the case 1? or does not change almost nothing respect the case? Is there a loss of quality between case 1 and 2?Last edited by marcorocchini; 23rd Mar 2017 at 05:07.
	CPU load will increase with each ColorMatrix() instance.
 About quality loss: https://forum.videohelp.com/threads/382794-during-colomatrix-conversion-get-I-a-loss-of-quality
	Of course. If you run up a flight of stairs then back down you're back where you started but it took time and you expended energy.
 You've just wasted CPU time and...
 The conversion is not lossless. So yes, you've lost quality, though you may not be able to see it. And ColorMatrix clamps super-blacks and super-whites by default. So you will lose those if there are any in your video. Why bother asking a question like this since you can test it yourself very easily?
	Hey cat...U been drinking again??
 [Attachment 41030 - Click to enlarge]'Do I look absolutely divine and regal, and yet at the same time very pretty and rather accessible?' - Queenie
	Groucho2004GuestLast edited by Groucho2004; 24th Mar 2017 at 08:28.
  Not a cat?By poisondeathray in forum Off topicReplies: 4Last Post: 14th Oct 2014, 18:26
  NDJAMENA please help the catBy marcorocchini in forum Newbie / General discussionsReplies: 4Last Post: 20th Jun 2014, 04:11
  cat--->mp4 help pleaseBy marcorocchini in forum Newbie / General discussionsReplies: 12Last Post: 16th Jun 2014, 14:17
  Why ma cat il FliPpEd?By marcorocchini in forum Newbie / General discussionsReplies: 40Last Post: 1st Jun 2014, 07:19
  please can u help my cat?By marcorocchini in forum Newbie / General discussionsReplies: 10Last Post: 20th Mar 2014, 15:51
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
