My workflow is to capture to Lagarith/AVI with AmaRecTV (VirtualDub capture is too flaky on my system), then re-encode to the desired codec and do trimming and audio sync correction (if I used an external TBC) at the same time. Usually that's all through FFmpeg, though if I have a difficult capture in multiple files, I will concatenate in VirtualDub and then use the external encoder function.
Results 31 to 33 of 33
I'm pretty much with JVRaines in capturing with AmarecTV (v3.1 the later ones require you to purchase their codec) to Lagarith (YUY2) audio PCM, edit in Vdub and then usually use Avisynth and HC BatchGUI (HC Enc) to encode to Mpeg2, or use Vidcoder, Xmedia Recode or MeGUI to encode to x264.
Lagarith still gives me slightly smaller .avi files than any of the other lossless codecs mentioned here, and a 2.6GHz Intel C2D with 4Gb DDR2 RAM is more than capable of capturing without ANY dropped frames in 64-bit Windows 10 (or 64-bit Windows 7). UT Video might be a better option for long-term storage as it is at least still being developed . . . ? Have Fun!
Capturing VHS-C, Hi8 and DV tapes, but which FINAL format for viewing?
By joeman in forum Video ConversionReplies: 11Last Post: 14th Nov 2014, 09:08 -
Capturing Video 8 tapes to digital format
By DaMan4x4 in forum Capturing and VCRReplies: 8Last Post: 22nd Aug 2014, 01:28 -
What is the best format to convert VHS-C tapes to?
By Theresa in forum Newbie / General discussionsReplies: 16Last Post: 15th Jun 2014, 10:26 -
I need Help - Archiving old VHS tapes to Digital Format
By video80 in forum Capturing and VCRReplies: 27Last Post: 27th Mar 2014, 21:54 -
Capturing Lossless VHS Tape
By zack28 in forum Newbie / General discussionsReplies: 33Last Post: 24th Feb 2014, 13:43
