Hi cats,
is it possibile that only AVFS serve in YUY2 .avi uncompressed? is there another programs that do it in this mode? thanks
No, for example 4:2:0 is frameserved as YV12. But for YUV422, it will use YUY2
maybe makeavis (ffdshow old versions) , maybe avs2avi-0.3 , I can't recall if YUY2 was supported. avfs is better alternative in terms of stability, compatibility. None of my newer computers have makeavis or avs2avi installed
see post#4 for a mirror . You might need special install or modify inf for windows 7,8,10
https://forum.videohelp.com/threads/348212-Looking-for-copy-of-avs2avi-wrapper-v0-3
and check sourceforge for old ffdshow makeavis versions -
ok but both makeavis and avs2avi have a proper fourcc, that is not a YUY2 fourcc. Possibly I need a virtual file that have YUY2 as fourcc
AVS2AVI is good but it have "AVAV" as fourcc
does exist a similar of AVFS? that do a flagged interlace YUY2 .AVI out
By marcorocchini in forum Newbie / General discussionsReplies: 0Last Post: 10th Mar 2017, 08:30 -
decoder .avi YUY2 codec VFW that is not FFDshow
By marcorocchini in forum Newbie / General discussionsReplies: 3Last Post: 9th Oct 2016, 15:09 -
AVISource: couldn’t locate a decompressor for fourcc dvsc
By atsay in forum Video ConversionReplies: 7Last Post: 22nd Oct 2015, 15:11 -
is there a VFW decoder for mpg2 FOURCC ? (not ffdshow)
By marcorocchini in forum Newbie / General discussionsReplies: 0Last Post: 14th Dec 2014, 12:47 -
from yuy2 to uyvy
By marcorocchini in forum Newbie / General discussionsReplies: 7Last Post: 29th Nov 2013, 12:44
