Does anyone know what's the big difference is between the 2 files in the Mp4 H.264 MPEG-4? File 51 is played normal but file 64 only plays slow and stucks in picture on my old computer. It is the same when i try to convert any file to Mp4 H.264 MPEG-4, 1280*720.
General
Complete name : I:\Ny Mapp (15)\51\_-_.mp4
Format : MPEG-4
Format profile : Base Media
Codec ID : isom (isom/iso2/avc1/mp41)
File size : 721 MiB
Duration : 22 min 23 s
Overall bit rate mode : Constant
Overall bit rate : 4 502 kb/s
Writing application : Lavf56.36.100
Video
Format : AVC
Format profile : Main@L3.1
Format settings, CABAC : Yes
Format settings, ReFrames : 3 frames
Codec ID : avc1
Bit rate mode : Constant
Bit rate : 4 340 kb/s
Width : 1 280 pixels
Height : 720 pixels
Display aspect ratio : 16:9
Frame rate mode : Constant
Frame rate : 25.000 FPS
Standard : PAL
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.188
Stream size : 695 MiB (96%)
Color range : Limited
Audio
Format : AAC
Format profile : LC
Codec ID : 40
Bit rate : 157 kb/s
Channel(s) : 2 channels
Sampling rate : 48.0 kHz
Frame rate : 46.875 FPS (1024 spf)
Compression mode : Lossy
Stream size : 25.2 MiB (3%)
Default : Yes
Alternate group : 1
General
Complete name : I:\Ny Mapp (15)\64\_-_.mp4
Format : MPEG-4
Codec ID : M4V (M4V /mp42/isom)
File size : 505 MiB
Duration : 22 min 4 s
Overall bit rate : 3 198 kb/s
Encoded date : UTC 2016-03-16 21:05:52
Tagged date : UTC 2016-03-16 21:06:05
©TIM : 00:00:00:00
©TSC : 25
©TSZ : 1
Video
Format : AVC
Format profile : Main@L4.1
Format settings, CABAC : No
Format settings, ReFrames : 2 frames
Codec ID : avc1
Bit rate : 3 006 kb/s
Height : 720 pixels
Standard : PAL
Color space : YUV
Bit depth : 8 bits
Bits/(Pixel*Frame) : 0.130
Stream size : 475 MiB (94%)
Language : English
Tagged date : UTC 2016-03-16 21:05:52
Color primaries : BT.709
Transfer characteristics : BT.709
Matrix coefficients : BT.709
Audio
Format : AAC
Format profile : LC
Codec ID : 40
Source duration : 22 min 4 s
Bit rate mode : Variable
Bit rate : 192 kb/s
Maximum bit rate : 292 kb/s
Stream size : 29.9 MiB (6%)
Source stream size : 29.9 MiB (6%)
Language : English
	Hard to tell. Normally, I would have guessed file 64 to player better than 51 because it has less bitrate and doesn't use CABAC. Did you try different players (VLC, MPC-HC)? Hardware specs of the PC?
  H.264/MP4 codec ?By Tafflad in forum Newbie / General discussionsReplies: 88Last Post: 11th May 2014, 18:25
  MPEG StreamClip - H.264 MP4 w/AC3 audio loses audioBy the_wallcrawler in forum Video ConversionReplies: 5Last Post: 25th Jan 2014, 04:05
  Huffyuv AVI to h.264 mp4By satellite15 in forum Video ConversionReplies: 2Last Post: 6th Jan 2013, 17:23
  Demux MKV/h.264/AC3-5.1 to MP4/h.264/AC3-5.1 (using MP4tools / mkvextract)By xnu in forum Video ConversionReplies: 2Last Post: 17th Jun 2012, 07:42
  Remux .264 to mp4 using My MP4BoxGUI?By Yoshi8765 in forum Newbie / General discussionsReplies: 2Last Post: 15th Apr 2012, 12:16
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
