    Mar 2017
    Australia
    Hi All
    Anybody know anything about Wondershare video converter ultimate or Winx HD video converter.
    Seems from google they are loaded with Malware
    Any advice appreciated
  2. Member leghorn's Avatar
    Apr 2007
    Germany
    From what I've heard and experienced Wondershare is a bunch of cheap dupes. Don't spend your money on them, so to speak. But -as always- opinions differ.
    I for one suggest you try a converter from the VSO ConvertX series, like ConvertXtoVideo or Blu-ray Converter.
    Das Leben ist eine Nebelwand voller Rasierklingen. (C. Bukowski)
    Jul 2008
    Old Dominion
    As stated, the VSO software is a safe and good bet. Most of those programs use ffmpeg anyway.
    Mar 2017
    Australia
    Thanks Guys
    Mar 2017
    Australia
    Hey Leghorn hope you are out there somewhere
    I am trying ConvertXtovideo and it is very impressive
    My source video is recorded movie from television M2TS
    When played on VLCplayer or Potplayer or DVD player the movie fills the screen completely.
    When I convert to any other format using the conversion program The resulting video does not fill the screen on any players as it did before conversion.
    Am I stupid ? Is there some setting I need to use to have the converted video fill the screen as before ?
    Hoping you have some experience with the program and can advise me
