I am trying to archive home movies on VHS.
I recently contacted a service called Rafik. They use H.264, and then make a BluRay or DVD copy as well.
Is this a good format/way to archive my VHS? And should I go with BluRay or DVD for the second copy?
Depends on the encoder settings your archive service uses. H.264 encodes are very compact. And most think the quality is good for archiving. It would be great if they would process a sample file from you to see how it looks to you.
If the videos are very important to you, you might use a less 'compacted' format. Downside is the files can get very large, and the costs will rise.
Universally, MPEG2/DVD quality is still ok from VHS tapes, if it's handled properly. Burned DVD discs are good for older relatives that only have a DVD player.
Most Blu-rays are ADVC, H.264 format and very good quality. So, myself, I would recommend H.264 encoding and maybe a less compact (Usually higher quality) format file that you might use for future edits.
But read some reviews about your archiving company and do a lot of research if a lot of money is involved.Last edited by redwudz; 16th Mar 2017 at 19:04.
Rafik NY? They seem like a good facility and also provide uncompressed capture. If you liaise with them they can probably tell you their process and the data rate they use. Generally >8mbits for H264 is what you need IMHO. With the pervasiveness of the H264 format you can be fairly confident it will be playable for many years to come.
For long term archiving I would personally stay away from optical media (dvd/blu-ray) and instead buy a couple of Hard Drives to store your files (2 copies). Store them separately from one another. Then recopy the data onto a new set of hard disks every 5 years or so.Last edited by Topsy; 17th Mar 2017 at 04:34.
convert a vhs format video to dvd
By shom44 in forum CapturingReplies: 13Last Post: 27th Aug 2016, 12:37 -
What is the best format to convert VHS-C tapes to?
By Theresa in forum Newbie / General discussionsReplies: 16Last Post: 15th Jun 2014, 10:26 -
.264 video format
By Ibby14 in forum Video ConversionReplies: 12Last Post: 12th Nov 2013, 05:50 -
Convert HD-PVR H.264 TS to Android-friendly format?
By timg11 in forum Video ConversionReplies: 11Last Post: 28th Feb 2013, 08:40 -
good laptop for x.264 encoding
By mmbwdpnz in forum ComputerReplies: 18Last Post: 9th Feb 2013, 11:56
