I have new burner since 2 weeks. Very strange way of burning. Kind of sinusoidal wave burning but only from beginning but discs are ok after burning and during copy.
Problem is i have problem with burning BDRE 50Gb Verbatim with speed higher than 0.9x . Do i need to change something in IMG BURN? or maybe new format of that disc? With 0.9x this is almost 3h burning 45GB ISO file.
I have 1.31 and here is history
That Verbatim Disc is from 2 years. That Pioneer is younger manufactured1.34 DVD writing operation is improved on the specific application.
DVD Playability Improvement
1.33 Support New BD-R SL Media (16x Writing : MKM 6)
Improvement of the recording quality with BD-R SL(4x Writing : Millenniata)
Improvement of the recording quality with BD-R/RE
1.32 Improvement of the recording quality with CD-R
Improvement of the recording quality with DVD-RAM
1.31 Improvement of writing problem under the specified condition with DVD-RAM
Improvement of the operational stability
1.30a Problems which unable to update ver1.30 with some PCs are solved.
1.30 Support New BD-R SL media(4x Writing : Millenniata)
Improvement of the recording quality with DVD-R/RW
BD Playability Improvement
1.20 Support New BD-RE TL media(2x Writing : SONY)
Support New BD-R TL media(4x Writing : Panasonic)
Improvement of the recording quality with DVD-RW
I dont need to write BD 16x i am writing only 4x. I only need to burn BDRE 50GB. Using that Verbatim Disc i cant even reach 21GB on 1st layers.
Any help? -
What is the name & manufacturer & model number of
Your bluray burner. -
I 20:57:36 Initialising SPTI...
I 20:57:36 Searching for SCSI / ATAPI devices...
I 20:57:36 -> Drive 1 - Info: PIONEER BD-RW BDR-S09 1.31 (D
(ATA)
I 20:57:36 Found 1 BD-RE XL!
I 20:58:53 Operation Started!
I 20:58:54 Destination Media Type: BD-RE (Disc ID: VERBAT-IM1-000)
I 20:58:54 Destination Media Supported Write Speeds: 2x
I 20:58:54 Destination Media Sectors: 23*652*352
I 20:58:54 Write Mode: BD
I 20:58:54 Write Type: DAO
I 20:58:54 Write Speed: 2x
I 20:58:54 Hardware Defect Management Active: No
I 20:58:54 BD-RE FastWrite: No
I 20:58:54 Link Size: Auto
I 20:58:54 Lock Volume: Yes
I 20:58:54 Test Mode: No
I 20:58:54 OPC: No
I 20:58:54 BURN-Proof: Enabled
I 20:58:54 Write Speed Successfully Set! - Effective: 8*990 KB/s (2x)
I 20:58:54 Advanced Settings - Optimal Writing Speed: No
I 20:58:55 Filling Buffer... (40 MB)
I 20:58:56 Writing LeadIn...
I 20:59:10 Writing Session 1 of 1... (1 Track, LBA: 0 - 20651007)
I 20:59:10 Writing Track 1 of 1... (MODE1/2048, LBA: 0 - 20651007)
I 20:59:10 Writing Layer 0... (LBA: 0 - 12219391)
but still its burning with speed 0.9 even after full disc erase [ 3h:30m] -
thread can be closed
i turned on BDRE-Fast Write bcoz i didnt formatted disk without spare aresas. Now i am burning with speed 2.0 80 minutes.
Pioneer BDR-2209 Blu-Ray Burner
By golfnut in forum DVD & Blu-ray WritersReplies: 2Last Post: 30th Jul 2015, 00:55 -
Pioneer BDR-206D?
By NLP in forum DVD & Blu-ray WritersReplies: 11Last Post: 28th Sep 2014, 03:08 -
Strange use for BDR-LTH discs
By louv68 in forum MediaReplies: 2Last Post: 20th Apr 2014, 03:05 -
BD Writer Pioneer BDR-S09XLT installing problem
By X_Paul in forum DVD & Blu-ray WritersReplies: 2Last Post: 11th Mar 2014, 16:57 -
Bdr-207dbk
By medway in forum DVD & Blu-ray WritersReplies: 7Last Post: 17th Sep 2012, 14:59
