  1. Just started the vcd thing and I can't get none of my avi files to convert to vcd....If I try to use avi2vcd I get this message Source file uses compressed audio avi2vcd can not encode compressed audio...If I use TMPGenc I get the error that file is not supported...doesn't matter what file type I use either...can anyone please help me with this annoying problem?
  2. What type of avi files are you trying to convert ?? need more info dude
  3. This is what I see when I go to properties - summary of the movie which is Jason X
    Audio
    Audio Format - MPEG Layer-3
    Average Data Rate - 12.00kb/second
    Sample Rate - 48.00khz
    Channels - 2 Stereo
    Video
    Stream Name - Videostream
    Frame Width - 352 Pixels
    Frame height - 240 pixels
    Play Lenght - 1657.550 seconds
    frame count - 33151
    Data Rate - 86.711 kb/second
