Hello,
I'm importing an MP4 video into my Premier Pro/After Effects timeline and cannot get any audio track out of it.
Information:
The mp4 video does play audio playback on video-viewing programs (VLC WMP)
The video is from someone who edited the clip, I need to re-edit it.
What I've tried:
Clearing Cache. (100% cleared along with new destination for memory cache)
Exporting Audio only (mp3) from the file via Encoder CC. (Just produces a long silent audio file)
Exporting Mp4 into H264 via Encoder CC: It produced no sound.
PC Specs:
i7700k @ 4.2GHZ
16 GB Ram DDR4
GPU: NVidia GTX 970
Media Info:
General
Format : MPEG-4
Format profile : Base Media / Version 2
Codec ID : mp42 (mp41/mp42/isom)
File size : 1.08 GiB
Duration : 56 min 57 s
Overall bit rate : 2 727 kb/s
Encoded date : UTC 2017-03-03 00:19:17
Tagged date : UTC 2017-03-03 00:29:09
IsTruncated : Yes
Video
Format : AVC
Format profile : High@L3.1
Format settings, CABAC : Yes
Format settings, ReFrames : 2 frames
Format settings, GOP : M=2, N=30
Codec ID : avc1
Bit rate mode : Variable
Bit rate : 4 997 kb/s
Maximum bit rate : 768 kb/s
Width : 1 280 pixels
Height : 720 pixels
Display aspect ratio : 16:9
Frame rate mode : Constant
Frame rate : 29.970 (30000/1001) FPS
Original frame rate : 25.000 FPS
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.181
Stream size : 1.99 GiB
Title : Core Media Video
Color range : Limited
Color primaries : BT.709
Transfer characteristics : BT.709
Matrix coefficients : BT.709
Audio
Format : AAC
Format profile : LC
Codec ID : 40
Source duration : 56 min 57 s
Bit rate mode : Constant
Bit rate : 128 kb/s
Channel(s) : 2 channels
Thank you!
[Solved] MP4 No Sound [bad record without sound]
By gallatatv in forum Software PlayingReplies: 5Last Post: 4th Jan 2016, 18:30 -
DVDFab No Sound when creating MP4. Change extension to M4V and sound works
By hackerjunk in forum DVD RippingReplies: 2Last Post: 5th Jun 2014, 15:04 -
MP4 no sound no video with Isom Codec
By Lukamo in forum Newbie / General discussionsReplies: 6Last Post: 24th Feb 2014, 14:08 -
sound editing in video file
By allanG in forum Latest Video NewsReplies: 3Last Post: 3rd Nov 2013, 04:12 -
Mp4 Video File Has No Sound
By Memto in forum Software PlayingReplies: 20Last Post: 26th Aug 2013, 01:24
