Hi,
I am trying to play an AVI file but vant get it to play in VLC because it says it is unkown file type... but in file manager show up as an AVI file.
IThis file came up from a DVD RW DLayer 8.5GB disc that for some reason has problems reading. I have bought SkipDr in order to try to fix the DVD but the problem persisted and didnt resolve me the issue.. so I took it to a Videi shop and they put the DVD is their cleaning machine. It got better but still is very slow reading and some files do not open.
I tried to make a copy of the disk and could make it because it was constantly freezing the system and not responding so I used the software IsoPuzzle and created a iso file, a copy of the DVD itself. Then i went to Poweriso and extracted the video file i want. But it didnt open but the size is the same of the disk and it shows up as an AVI file.
I then tried to use DivFix plus, Gspot, VirtualDub and nothing.. the file do not open and errors are File Unknown, Not a valid AVI file, and so on...
So I would like if anyone could help me how to open or manipulate this video file that shows up as an AVI but apparently is not an AVI file...
If it is indeed an AVI file then it is not "a DVD" but rather a data disc that just happens to use a DVD blank. So the programs you quote are designed for a regular "DVD" ie 2 folders, one called VIDEO_TS and containing many files, VOB, IFO and BUP type and an AUDIO_TS folder containing nothing... So a MediaInfo report should identify what the file is..
SONY 75" Full array 200Hz LED TV, Yamaha A1070 amp, Zidoo UHD3000, BeyonWiz PVR V2 (Enigma2 clone), Chromecast, Windows 11 Professional, QNAP NAS TS851 -
If that is the only information that you are seeing, it's not a video (avi) file or it's corrupted.
Look at the screenshots here (the second shows the output of a proper video file): https://mediaarea.net/en/MediaInfo/ScreenshotsGoogle is your Friend -
Definitely sounds like the file is corrupted. Could be from the original write to the DVD, or because of the trouble you're having reading it. If the file was corrupted in the original write process to the disc, then you're SOL... unless you have access to the original file that it was written from.
I would venture a guess that if you examine this AVI file in a hex editor, it will show up as all zeroes. (I say that because I've had similar problems myself in the past).
Have you tried reading the disc using a different DVD drive, and do you have any issues reading any other discs in this drive?Do or do not. There is no "try." - Yoda
.TS file to .AVI file
By NEO_Ness in forum EditingReplies: 3Last Post: 14th Dec 2015, 05:28 -
how to create a virtual file linked to the a real .avi video file ?
By marcorocchini in forum Newbie / General discussionsReplies: 13Last Post: 5th Dec 2015, 08:34 -
Can't convert an AVI file to a readable H.264 file with Adobe Media Encoder
By JeffTchaderjian in forum Video ConversionReplies: 0Last Post: 1st Jun 2013, 09:26 -
how to merge sub file into .avi video file?
By neiffee9211 in forum SubtitleReplies: 3Last Post: 12th Nov 2012, 12:40 -
How can I Burn DVD using avi file and .srt file as subtitle
By Gayanx in forum Authoring (DVD)Replies: 7Last Post: 15th Jul 2012, 00:56
