I lost the CD that came with the capture card.
The capture card, or capture stick, is: Compro VideoMate C200 Pro. The web page for this product is this. On this web page, at the top, there is a link called "Download", and when I click on it, the web browser goes to this web page, where there are 4 drivers. I am unable to identify which of these 4 drivers is the one that is for Compro VideoMate C200 Pro. Is it the latest one? Or none of them are?
No.
Click on the 'Support' button and then chose 'Driver and Software'. Select your product from the PC-Tv drop down list and you will see the appropriate driver for your OS. -
Actually, I rechecked and the 'Download' link is a mere shortcut to that self-same page.
Again, just read the page carefully and select the driver for your OS. Also download the driver user-guide to be certain.
It only mentions Win7 so maybe you had this for an older PC ?
new usb capture card vs old pro pci capture card
By codemaster in forum Capturing and VCRReplies: 1Last Post: 6th Dec 2013, 00:23 -
Unable to switch to capture mode.
By yksratnak in forum Newbie / General discussionsReplies: 2Last Post: 1st Dec 2013, 11:28 -
Problem with Asus Virtual Capture Device - Unable to re-install driver
By Cathode in forum Capturing and VCRReplies: 3Last Post: 17th May 2013, 13:51 -
Multi Channel Capture Card with WDM driver
By skewcrap in forum Capturing and VCRReplies: 2Last Post: 4th Apr 2013, 11:23 -
Need help getting my DC10 AV/DV card working, maybe driver
By Helstedxd in forum Capturing and VCRReplies: 1Last Post: 4th Aug 2012, 10:44
