Im having trouble turning my vhs into digital
https://www.youtube.com/watch?v=Wtcox7mis8c
Every time I try take the footage of the video records really wobbly as shown above, the image is clear so it cant really be a problem with the camera.
I've tried using a different type and brad of tape and it still came out with the same wobbly effect, i also changed programmes I've used like 4 different ones .
please help i need this camera for a shoot very soon
Camera is a JVC GR-AX280 and I'm using easy cap
Results 1 to 11 of 11
You spelled color "coloUr".
Where are you?
Where is the camera from?(was it imported)?
Have you tried PLAYING the tape to a television? How does it look? -
Does it look like this on the camera's view screen? If so, the transport is in need of repair.
I would concur with the above.
Was this easycap a cheapy ?. The issue could also be a bad driver. What is your OS ? The older easycaps have driver issues beyond WinXP although if you are lucky some do work ok. -
yh it was a cheap capturecard, im going to try a friends out tomorrow to see if it is the easycap, will give an update, thanks for the help everyone
So after going over to a friends and trying the cassettes on his set up, it is literally just a problem with the capture card. Thanks everyone for the help.
VHS to PC capturing help please, screen flickers only on capture not on vhs
By Rdakin7593 in forum Capturing and VCRReplies: 7Last Post: 25th Aug 2015, 11:52 -
Need Help Choosing Capture Card, TBC, and Software/Settings for VHS/8mm VHS
By Duder_Me in forum Newbie / General discussionsReplies: 1Last Post: 25th Apr 2014, 10:47 -
By Duder_Me in forum Capturing and VCRReplies: 2Last Post: 25th Apr 2014, 09:42 -
Honestech vhs to dvd 5.0 - vhs capture loses picture after 5 minutes
By NJA in forum MediaReplies: 1Last Post: 19th Jun 2013, 10:26 -
Can an S-VHS Player and S-Video Output Cable Benefit Standard-VHS Capture?
By Avagadro1 in forum Capturing and VCRReplies: 34Last Post: 5th Dec 2012, 18:31
