Capture Video
My setup is a..
VCR: Panasonic PV-S7670 SVHS
Capture Device: Diamond VC500 (using S-Video)
Capture Software: AmaRecTV
Capture Codec: PICVideo MJPEG 3.0
Yes, I use Elmo for my test captures whenever I am trying something new. I find that the best because of all of the colors. I am still pretty new to this and would like to contiunously get better. Please let me know how I can make my captures better. I don't like the blurriness of the bottom. How do I remove something like that?
Are you talking about the head-switch noise at the bottom of the image? That's normal for most videotape captures. It's an artifact that nobody saw on old tube TVs because it was hidden in the overscan area. You can crop it or cover it with black and render.
Horizontal time base jitter, oversharpening halos, block artifacts and DCT ringing from MJPEG compression, blown out brights, illegal colors. Converting MJPEG full range YUV to normal limited range YUV helps. You should adjust the capture devices proc amp to get levels closer. Use an old DVD recorder with line TBC in passthrough mode to reduce the horizontal time base jitter. Turn off (or reduce) the VCR's sharpening filter to reduce oversharpening halos.
Can I jump in and ask if it's always better to adjust the device's proc amp values rather than adjusting after capturing with default values? I use a Hauppauge USB Live2 and AmarecTV and am getting better results since capturing at default values, checking the values using the line "Crop(8,8,-8,-8).ColorYUV(Analyze=True).histogram("classic")" line in my avisynth scripts and tweaking accordingly using the Tweak() function. (The crop command is to reduce the effect of the black borders that I always get with the USB Live2) I thought I'd read somewhere that a lot of the lower end capture devices capture at the default values anyway and then adjust in software, so if you're going to adjust anyway . . . ? Is your answer the same for adjusting sharpening in the capture device's proc amp?
Last edited by TimA-C; 12th Mar 2017 at 14:03. Reason: Correcting name of capture device
Researching for VHS digitizing setup. Soliciting feedback, recommendations.
By avurgesser in forum Capturing and VCRReplies: 3Last Post: 6th Aug 2016, 21:35 -
Advice on best practice for USB3HDCAP VHS capture setup?
By Vodalus in forum Capturing and VCRReplies: 9Last Post: 1st Aug 2016, 19:25 -
Roast Me....Capture Setup
By Tykhon in forum Capturing and VCRReplies: 2Last Post: 21st Jun 2016, 22:19 -
Proc amp for this setup (vhs ripping)
By anbu_zim in forum RestorationReplies: 4Last Post: 1st Dec 2014, 14:40 -
Help with VHS Capture Setup
By DoDanger in forum Capturing and VCRReplies: 43Last Post: 13th Oct 2014, 04:53
