Results 1 to 23 of 23
  1. I am using ffmpeg, but please bear with me cause I am absolutely newbie
    The file I got:
    Duration: 01:08:47.98, start: 12222.532978, bitrate: 4463 kb/s
    Program 37
    Stream #0:0[0x2f5]: Video: h264 (High) ([27][0][0][0] / 0x001B), yuv420p(tv, bt470bg, top first), 704x576 [....]
    Stream #0:1[0x2f6](dan): Audio: aac_latm (HE-AAC) ([17][0][0][0] / 0x0011), 48000 Hz, stereo, fltp
    Stream #0:2[0x2f7](dan): Subtitle: dvb_teletext ([6][0][0][0] / 0x0006)
    Stream #0:3[0x2f8](dan): Subtitle: dvb_subtitle ([6][0][0][0] / 0x0006)
    Stream #0:4[0x2f9](dan): Subtitle: dvb_subtitle ([6][0][0][0] / 0x0006) (hearing impaired)
    Stream #0:5[0x2fa]: Unknown: none ([5][0][0][0] / 0x0005)
    Stream #0:6[0x2fb]: Unknown: none ([11][0][0][0] / 0x000B
    I need to extract the stream #0:3
    I have been trying this (My file is named "film"):
    ffmpeg -i film.ts -map 0:3 -scodec dvdsub film.srt
    It does not work
  2. "It does not work" is a bad error description. That said, I have never been able to extract dvb_subtitle from ts successfully using ffmpeg. Try ProjectX. If you upload a sample others may give you more suggestions.
  3. The full eror discription is a "little" long :
    [h264 @ 00000000025e32c0] SPS unavailable in decode_picture_timing
    [h264 @ 00000000025e32c0] non-existing PPS 0 referenced
    [h264 @ 00000000025e32c0] decode_slice_header error
    [h264 @ 00000000025e32c0] no frame!
    [h264 @ 00000000025e32c0] mmco: unref short failure
    [h264 @ 00000000025e32c0] number of reference frames (0+4) exceeds max (3; probably corrupt input), discarding one
    [aac_latm @ 00000000025e3f40] element type mismatch 1 != 0
    [mpegts @ 00000000001763a0] start time for stream 3 is not set in estimate_timings_from_pts
    [mpegts @ 00000000001763a0] start time for stream 4 is not set in estimate_timings_from_pts
    [mpegts @ 00000000001763a0] PES packet size mismatch
    Last message repeated 1 times
    [mpegts @ 00000000001763a0] Could not find codec parameters for stream 5 (Unknown: none ([5][0][0][0] / 0x0005)): unknown codec
    Consider increasing the value for the 'analyzeduration' and 'probesize' options
    [mpegts @ 00000000001763a0] Could not find codec parameters for stream 6 (Unknown: none ([11][0][0][0] / 0x000B)): unknown codec
  4. I see.
    If you are ok with OCR try Subtitle Edit.
  5. Thanks - But I first would like to know if this is the right "command" and "syntax":
  6. DVB subs are not DVD subs.
    While similar (image based), they're way more complicated, especially regarding timing and presentation.
    Plus you'd need to OCR them to get a SRT. Something which FFMPEG isn't doing at all, afaik.
    Maybe you're lucky and the Teletext-stream offers subtitles, which you can try to extract using ccextractor.
  7. Originally Posted by T-buch View Post
    I believe you are supposed to do something crazy like
    -c:s dvdsub -f rawvideo film.sup
    or
    -c:s dvbsub -f rawvideo film.sup
    Interestingly, ffmpeg doc knows about -f dvd_subtitle and -f dvb_subtitle but they don't really result in anything useful either, from what I can see.
    It creates files (well, maybe not for your specific sample if there are other problems) but they can't usually be read. And like T-buch said if you want text subtitles (srt) you need to OCR anyways.
  8. Thanks... I guess cause i am a little confused ... Why?
    Because when I do this:
    ffmpeg -i film.ts -map 0:0 -map 0:1 -map 0:3 -vcodec copy -acodec copy -scodec dvdsub film.mkv
    I got this results
    Input #0, matroska,webm, from 'film.mkv':
    Metadata:
    ENCODER : Lavf57.56.100
    Duration: 00:45:55.11, start: 0.462000, bitrate: 2820 kb/s
    Stream #0:0: Video: h264 (High), yuv420p(tv, bt470bg, top first), 704x576 [SAR 16:11 DAR 16:9], 25 fps, 25 tbr, 1k tbn, 50 tbc (default)
    Metadata:
    DURATION : 00:45:54.997000000
    Stream #0:1(dan): Audio: aac_latm (HE-AAC) ([2][22][0][0] / 0x1602), 48000 Hz, stereo, fltp (default)
    Metadata:
    DURATION : 00:45:54.251000000
    Stream #0:2(dan): Subtitle: dvd_subtitle (default)
    Metadata:
    ENCODER : Lavc57.64.101 dvdsub
    DURATION : 00:45:55.110000000
    Everything is fine but it stops at 45:00 (the original file is 01:08:47)
    Error:
    [matroska @ 00000000028d0660] Timestamps are unset in a packet for stream 0. This is deprecated and will stop working in the future. Fix your code to set the timestamps properly
    [matroska @ 00000000028d0660] Can't write packet with unknown timestamp
    av_interleaved_write_frame(): Invalid argument
  9. Actually I just need a file so Handbrake can see the subtitle - so any and every ideas in that way, I welcome very much
  10. Try:
    ffmpeg -fflags +genpts -i film.ts -map 0:0 -map 0:1 -map 0:3 -c:v copy -c:a copy -c:s dvdsub film.mkv
    I assume you want to hardcode the subs in HandBrake? ffmpeg can do that itself though I haven't tested it with such ts files.
    https://trac.ffmpeg.org/wiki/HowToBurnSubtitlesIntoVideo
  11. Thanks again - I wil try that
    What I want is to convert the MPEG-TS-file (kind of AVC H.264 codec) to MKV (H.265), Trimmed (The last of the file must be cut away - so its 0:00:00 - 0.59.01 (H.MM.SS)) with the the ability to choose subtiles (so no Hardcore/burn in subtitle)
  12. ffmpeg -i film.ts -map 0:0 -map 0:1 -map 0:3 -to 00:59:01 -c:v libx265 -crf 20 -preset medium -c:a copy -c:s dvdsub film.mkv
  13. It works except that there is no sound in VLC ?? (It works fine in ffplay.exe)
  14. Problem is the latm_aac which isn't extracted by ffmpeg. You can either convert (to e.g. aac or opus):
    ffmpeg -i film.ts -map 0:0 -map 0:1 -map 0:3 -to 00:59:01 -c:v libx265 -crf 20 -preset medium -c:a aac -c:s dvdsub film.mkv
    ffmpeg -i film.ts -map 0:0 -map 0:1 -map 0:3 -to 00:59:01 -c:v libx265 -crf 20 -preset medium -c:a libopus -c:s dvdsub film.mkv
    Or extract audio using eac3to:
    eac3to film.ts 2:audio.aac
    Then do ffmpeg:
    ffmpeg -i film.ts -i audio.aac -map 0:0 -map 1:0 -map 0:3 -to 00:59:01 -c:v libx265 -crf 20 -preset medium -c:a copy -c:s dvdsub film.mkv
  15. Good
    VLC can play the latm_aac in the original MPEG-TS-file so why not in the MKV-file (but mayby that a question for a VLC tread)
    Is there any advantage to using eac3to first?
    When doing the audio converting in ffmpeg how to set the audio sampling rate and the biterate to 112 kbps?
    I tried this (with no luck): ffmpeg -i film.ts -map 0:0 -map 0:1 -map 0:3 -ss 0:03:22 -to 00:45:20 -c:v libx265 -crf 20 -preset medium -c:a aac -ar 41100 -aq 112 -c:s dvdsub film.mkv
  16. Member netmask56's Avatar
    Sep 2005
    Sydney, Australia
    Post a MediaInfo report on the TS file
  17. Originally Posted by T-buch View Post
    The eac3to+ffmpeg solution losslessly copies the audio instead of re-encoding.
    -ar 41100 -aq 112
    -ar 41100 -b:a 112k
    (But I would not set -ar. It will use the one in the source which is 48000 and pretty much standard for video files.)
  18. Originally Posted by netmask56 View Post
    General
    Complete name : D:\ffmpeg\bin\film 01.ts
    Format : MPEG-TS
    File size : 2.14 GiB
    Duration : 1 h 8 min
    Overall bit rate : 4 464 kb/s
    Network name : Kabelplus
    Original network name : 1 degree W (Telenor)
    Video
    Menu ID : 37 (0x25)
    Format : AVC
    Format profile : High@L3
    Format settings, CABAC : Yes
    Format settings, ReFrames : 3 frames
    Format settings, picture structure : Frame
    Codec ID : 27
    Width : 704 pixels
    Height : 576 pixels
    Display aspect ratio : 16:9
    Frame rate : 25.000 FPS
    Standard : Component
    Color space : YUV
    Chroma subsampling : 4:2:0
    Bit depth : 8 bits
    Scan type : Interlaced
    Scan type, store method : Interleaved fields
    Scan order : Top Field First
    Color range : Limited
    Color primaries : BT.601 PAL
    Transfer characteristics : BT.470 System B, BT.470 System G
    Matrix coefficients : BT.601
    Audio
    Menu ID : 37 (0x25)
    Format : AAC
    Format profile : HE-AAC / LC
    Muxing mode : LATM
    Codec ID : 17
    Bit rate mode : Variable
    Channel(s) : 2 channels
    Sampling rate : 48.0 kHz / 24.0 kHz
    Frame rate : 23.438 FPS (1024 spf)
    Compression mode : Lossy
    Delay relative to video : -178 ms
    Language : Danish
    Text #1
    Menu ID : 37 (0x25)
    Format : DVB Subtitle
    Codec ID : 6
    Delay relative to video : 17 s 695 ms
    Language : Danish
    Text #2
    Menu ID : 37 (0x25)
    Codec ID : 6
    Delay relative to video : 17 s 685 ms
    Language : Danish
    Other
    ID : 759 (0x2F7)-100
    Menu ID : 37 (0x25)
    Format : Teletext
    Codec ID : 6
    Delay relative to video : -640 ms
    Language : Danish
    Menu
    Menu ID : 37 (0x25)
    List : 757 (0x2F5) (AVC) / 758 (0x2F6) (AAC, Danish) / 759 (0x2F7)-100 (Teletext, da) / 760 (0x2F8) (DVB Subtitle, Danish) / 761 (0x2F9) (DVB Subtitle, Danish) / 762 (0x2FA) () / 763 (0x2FB) ()
    Language : / Danish / Danish / Danish / Danish
  19. Originally Posted by sneaker View Post
    -ar 41100 -aq 112
    -ar 41100 -b:a 112k
    Okay I see
    I just wanted 41100 cause I thought the file would be smaller (However, it is probably very little).
  20. It will not be smaller. Size is determined by bitrate * duration. If you set bitrate to 112k that will determine the size. The sampling rate is not part of the formula.
  21. Member netmask56's Avatar
    Sep 2005
    Sydney, Australia
    TSDoctor should handle that file OK - but it is payware after a trial period.
  22. Thanks to you all - With your help and especially "Sneaker" I got a break through with ffmpeg
    But of course more questions comes to my mind - fell free to answer them or not :
    If you want a "proof" video file with compatibility with older devices and tvs- could that be the video:
    ffmpeg -i film.ts -c:v libx264 -profile:v baseline -level 3.0 film.mkv
    I don't know for the audio (not to mention the subtitle)
    Many of my recorded videos sound is to low - is there a way to normalize the sound level?
    is there code for "burn-in subtitles"?
