I download 2 .mpg files for each movie - is there a way to link these together to fit the entire movie on ONE cd??? I am using TMPGEnc - but will try another if recommended.
Thats not entirely true....It all depends how fussy you are about quality. You could merge both mpegs together using the merge option in TMPGenc and then reencode using a template like Kwags which you'll find in the tools section.....
Fitting more onto a DVD
By Woolen Llama in forum Authoring (DVD)Replies: 14Last Post: 23rd Sep 2010, 06:31 -
Fitting more in the dvd
By btkuehn in forum Newbie / General discussionsReplies: 2Last Post: 17th Nov 2008, 16:53 -
fitting more than one movie on a dvd
By LaLuna in forum Newbie / General discussionsReplies: 4Last Post: 21st Jan 2008, 18:15 -
Help Fitting Videos on CD...
By skinnerback in forum Video ConversionReplies: 4Last Post: 4th Sep 2007, 16:12 -
Fitting more onto single DVDs
By ells6363 in forum Authoring (DVD)Replies: 32Last Post: 18th Jun 2007, 02:57
