Just got a 5-disc DVD collection of John Denver from the 70's - "Around The World Live". There's artifacting of many, many vertical lines - like hundreds across the width of the image. Is this the result of a conversion issue from whatever the original tape format was?
The packaging gives the impression they meant to give this the royal treatment - I'm surprised the video has this glaring issue.
Results 1 to 16 of 16
All it would do is demonstrate exactly what I'm describing. The phenomenon I'm talking about is glaringly obvious. My experience in here is that "Post a sample" rarely if ever results in a better answer. Anyone who's familiar with this will know what I'm talking about. If you don't know the answer from my description you don't know the answer.
Sorry you perceive it that way. I stand by my response which is just honesty. If someone said "hey what causes these horizontal lines in moving parts of video on the web?" anyone who's familiar with deinterlacing is going to know it's video that wasn't deinterlaced. If someone has to ask to see this, any response they're going to give even after seeing it is going to be a guess - or an "I dunno". I've spent too much time going through the drill of creating such examples only to have it not net any particularly helpful info as a result.
I'm telling you, what I've described is clear. Imagine a couple of hundred or so evenly spaced, light vertical lines - that's what it looks like. The person who's going to know the answer is going to be someone familiar with processing pro video from that era - in this case shot overseas and issues that can arise. It's possible no one here fits that description. -
That's the one. It says Region 2 but plays in my LG Blu-Ray player.
Edit: The listing says Region 2 but I looked at the packaging, I don't see where a region is indicated anywhere. The only playback spec I see is NTSC English 4:3. Then again looking at other DVD's I'm not finding a region label either.Last edited by brassplyer; 11th Mar 2017 at 09:15.
This title was released in an NTSC version too: https://www.amazon.com/Around-World-Live-John-Denver/dp/B002N7W3N0
It should be possible figure out if its PAL or NTSC from the resolution. A long-time member of this forum ought to know how to determine that.Ignore list: hello_hello, tried, TechLord, Snoopy329 -
Are you getting the vertical lines when playing the physical DVD in a standalone player, or is it after you've ripped the DVD to your computer and are playing it using a software player?
Just because the box says NTSC doesn't mean the actual media inside the box really is NTSC.
And yes, asking for a sample of the offending video is a perfectly reasonable request, and yes, your response to that request was very rude and disrespectful. Sample videos are, in fact, quite often useful for users who are helping other users. If you can't be bothered to expend that little bit of effort to provide a sample when asked for it, don't expect others to expend much effort to help you solve your problem.Do or do not. There is no "try." - Yoda
Video To Video Converter Commercial Remover
By Ogilvy in forum EditingReplies: 4Last Post: 23rd Jun 2014, 01:43 -
Best commercial video editor
By Anonymous2 in forum EditingReplies: 41Last Post: 25th Feb 2014, 05:34 -
Background music for commercial video
By plnelson in forum Newbie / General discussionsReplies: 55Last Post: 24th Nov 2013, 15:38 -
How was/is commercial PAL video converted to NTSC?
By deadmeow in forum Newbie / General discussionsReplies: 4Last Post: 16th Mar 2013, 19:17 -
commercial use of video codecs
By cen in forum ProgrammingReplies: 23Last Post: 24th Mar 2012, 04:40
