I need help. I'm trying to convert a 1280x720 video into an 848x480 video, Everything goes fin until I reach 99.50% finished then the encoding just quits and it pops out an error. I have never encountered and error like this and I've spent the past 3-4 hours trying to fix it with no luck. I'm at my wit's end.Can someone please tell me what's going on and how to fix it? I've copied the error message into the spoiler below.
[spoiler]PLATFORM
OS Code: Microsoft Windows NT 6.2.9200.0
OS Name: Windows 10 Pro (x64)
Framework: 2.0.50727.8745 (v4.0)
AviSynth: AviSynth 2.60, build:Feb 20 2015 [03:16:45]
CPU Info: Intel(R) Core(TM) i5-6600 CPU @ 3.30GHz (~3312), 4 core(s)
RAM Total: 16323Mb
Language: ENU (1252, ".")
SystemDrive: C:
XviD4PSP
Version: 5.10.346.0
Created: 12.02.2015 13:46:56
AppPath: C:\Program Files (x86)\XviD4PSP 5
TempPath: D:\
FILES
[Ohys-Raws] Kobayashi-san Chi no Maid Dragon - 09 (MX 1280x720 x264 AAC).mp4 >
[Asuka Subs] Kobayashi-san Chi no Maid Dragon - 09 (848x480 h264 AAC).mp4
TASK
Format: MP4
Duration: 00:24:00:065 (34527)
VideoDecoder: DirectShowSource
Resolution: 1280x720 > 848x480
Aspect: 1.7778 > 1.7667
VCodecPreset: x264 Q18 HQ Film
VEncodingMode: Quality
VideoCodec: h264 > x264 (x64)
VideoBitrate: 2300 > Q18.0
Framerate: 23.976
SourceType: PROGRESSIVE
FieldOrder: UNKNOWN
AEncodingPreset: AAC-LC VBR 0.45
AudioCodec: AAC
AudioBitrate: 213 > VBR
Samplerate: 48000
Channels: 2
Normalize: 100%
Accurate: 10%
Gain: 7.178
SCRIPT
Import("C:\Program Files (x86)\XviD4PSP 5\dlls\AviSynth\functions\AudioFunctions.avs")
Import("C:\Program Files (x86)\XviD4PSP 5\dlls\AviSynth\functions\VideoFunctions.avs")
LoadPlugin("C:\Program Files (x86)\XviD4PSP 5\dlls\AviSynth\plugins\VSFilter.dll")
DirectShowSource("C:\Users\My Namel\Desktop\[Ohys-Raws] Kobayashi-san Chi no Maid Dragon - 09 (MX 1280x720 x264 AAC).mp4", fps=23.976, convertfps=true)
AmplifydB(7.178)
ConvertToYV12()
###[FILTERING]###
###[FILTERING]###
Lanczos4Resize(848, 480)
TextSub("C:\Users\My Name\Desktop\Kobayashi-san Chi no Maid Dragon - 09 test 2.ass")
AUDIO ENCODING
Encoding audio to: D:\\0007.m4a
AAC Q0.45 2ch 16bit 48000khz
neroAacEnc.exe: -ignorelength -q 0.45 -lc -if - -of "D:\\0007.m4a"
VIDEO ENCODING
Encoding video to: D:\\0007.264
x264 Q18.0 848x480 23.976fps (34527 frames)
avs4x26x.exe: -L x264_64.exe --crf 18.0 --ref 8 --deblock -1:-1 --direct auto --b-adapt 2 --trellis 2 --no-fast-pskip --psy-rd 1.0:0.1 --partitions all --me umh --rc-lookahead 50 --sar 1:1 --output "D:\\0007.264" "D:\\0007.avs"
raw [info]: 848x480p 1:1 @ 24000/1001 fps (cfr)
x264 [info]: using SAR=1/1
x264 [info]: using cpu capabilities: MMX2 SSE2Fast SSSE3 SSE4.2 AVX FMA3 AVX2 LZCNT BMI2
x264 [info]: profile High, level 3.1
x264 [info]: frame I:438 Avg QP:12.50 size: 99458
x264 [info]: frame P:10416 Avg QP:15.61 size: 14766
x264 [info]: frame B:23673 Avg QP:19.47 size: 2310
x264 [info]: consecutive B-frames: 4.5% 9.2% 9.5% 76.9%
x264 [info]: mb I I16..4: 14.6% 33.0% 52.3%
x264 [info]: mb P I16..4: 0.9% 3.1% 2.0% P16..4: 39.4% 8.7% 12.3% 1.1% 0.6% skip:32.0%
x264 [info]: mb B I16..4: 0.1% 0.3% 0.2% B16..8: 22.1% 2.8% 1.2% direct: 1.7% skip:71.7% L0:36.7% L1:57.5% BI: 5.8%
x264 [info]: 8x8 transform intra:44.1% inter:31.1%
x264 [info]: direct mvs spatial:100.0% temporal:0.0%
x264 [info]: coded y,uvDC,uvAC intra: 75.3% 92.6% 86.1% inter: 8.7% 16.8% 8.6%
x264 [info]: i16 v,h,dc,p: 28% 29% 26% 17%
x264 [info]: i8 v,h,dc,ddl,ddr,vr,hd,vl,hu: 21% 21% 30% 4% 5% 5% 5% 4% 6%
x264 [info]: i4 v,h,dc,ddl,ddr,vr,hd,vl,hu: 28% 20% 15% 6% 6% 7% 6% 6% 6%
x264 [info]: i8c dc,h,v,p: 47% 25% 20% 8%
x264 [info]: Weighted P-Frames: Y:0.6% UV:0.5%
x264 [info]: ref P L0: 66.9% 3.8% 13.2% 5.6% 3.4% 2.8% 2.3% 1.6% 0.4% 0.0%
x264 [info]: ref B L0: 78.7% 8.7% 6.0% 2.6% 1.6% 1.5% 1.0%
x264 [info]: ref B L1: 94.6% 5.4%
x264 [info]: kb/s:1400.16
x264 [total]: encoded 34527 frames, 71.32 fps, 1400.16 kb/s
MUXING
Video file: D:\\0007.264
Audio file: D:\\0007.m4a
Muxing to: C:\Users\My Namel\Desktop\[Asuka Subs] Kobayashi-san Chi no Maid Dragon - 09 (848x480 h264 AAC).mp4
MP4Box.exe: -fps 23.976 -add "D:\\0007.264" -add "D:\\0007.m4a" -new "C:\Users\My name\Desktop\[Asuka Subs] Kobayashi-san Chi no Maid Dragon - 09 (848x480 h264 AAC).mp4" -tmp "D:\"
Error:
[/spoiler]
UPDATE: well I guess spoilers don't work here.
Results 1 to 10 of 10
I would use CODE instead.
You said "an error" pops up. Which? Try to quote it as exactly as possible. You may be able to press Ctrl+C when this dialog appears.
Encoding audio and video seem to have finished. So the issue may be in the MP4 multiplexing at the end? -
Forgive my ignorance but what is CODE and how do I use it?
I have copied the error right to my post. All it says is Error:. Nothing else.
Anyway it doesn't finish encoding. As I said it gets to 99% and then just quits.Last edited by Mad_Dog; 10th Mar 2017 at 11:22.
Instead of using the bbCode [ SPOILER ], you would use the bbCode [ CODE ] instead.
The log lists no error message.
But it reports encoding audio, encoding video, and multiplexing with MP4Box. Obviously, encoding the video D:\\0007.264 finished before it tries to multiplex it with the audio D:\\0007.m4a to an MP4 file, and this seems to fail.Error:
MUXING
Well the log doesn't list what error it is. Also how to do I switch over from bbCODE to bbCODE [CODE]?
Well, how did you insert [spoiler] in the first place? Did you type that?
Simply substitute "spoiler" with "code" in your starting post.
__
The problem at hand ... well, my opinion is that the multiplexing step failed.
Do the files D:\0007.264 and D:\0007.m4a exist?
Does the file "C:\Users\My name\Desktop\[Asuka Subs] Kobayashi-san Chi no Maid Dragon - 09 (848x480 h264 AAC).mp4" exist?
Can you execute the whole MP4Box command line at a console prompt? ... Maybe create a batch file and execute it in the directory where Xvid4PSP 5 keeps its copy of MP4Box:
^this is a CODE blockCode:MP4Box.exe -fps 23.976 -add "D:\\0007.264" -add "D:\\0007.m4a" -new "C:\Users\My name\Desktop\[Asuka Subs] Kobayashi-san Chi no Maid Dragon - 09 (848x480 h264 AAC).mp4" -tmp "D:\" PAUSE
By the way, you should never use a root directory as temporary. Root directories always have a limited capacity, regarding the number of files to contain (and temporary files are easily created in hundreds, and forgotten to be removed). Always use subdirectories. For your movies as well: A desktop should never contain anything else than links.
Cant one MP4 video, error XviD4PSP 5
By adriannx in forum Newbie / General discussionsReplies: 1Last Post: 25th Dec 2015, 12:47 -
Resize in XVID4PSP
By rank17 in forum Video ConversionReplies: 2Last Post: 29th Jun 2014, 15:52 -
Resize a video to fit an in car video player
By _oldnich in forum Newbie / General discussionsReplies: 5Last Post: 15th Aug 2013, 14:30 -
Xvid4PSP's Gray Video Issue
By Phantoms Cry in forum Video ConversionReplies: 1Last Post: 4th Aug 2013, 20:57 -
xvid4psp hangs reboots the computer and video quality on xp and win 7
By rated_x75 in forum Video ConversionReplies: 0Last Post: 10th Dec 2012, 06:47
