So in an earlier version of A/d I could use [ and ] as A and B
In the latest it no longer works and I am forced to using some ridiculous setting of Ctrl+PgUp and Ctrl+PdDn
Even though their own site says something totally different, and get this, all google sites come up with different ways
Are they changing the settings for this superb editor with each version
Is there a way I can set it back to [ and ] (which is intuitive really speeds up my editing) without going back to the old version ?
I like the new version as it shows us key frame locations and doesn't reposition upon zoom which was very unnerving.
Thanks in advance !
Results 1 to 10 of 10
I tried to download the patch from http://avidemux.org/smif/index.php/topic,10336.msg55553.html but it doesnt exist
After doing a little reading around the ADM forum, I see the reason for changing it from [ and ] to Ctrl-PgUp and Ctrl-PgDn is because some keyboards do not have the [ and ] keys (and on others it is a two- or three-key combination), whereas Ctrl-PgUp and Ctrl-PgDn is far more universal. And the developer seemed to be adamant about leaving it that way.
You can edit the keyboard shortcuts in the source code, and rebuild it yourself. Of course, you'd probably have to perform that change every time you downloaded a new version. Don't ask me the details, as I've never tried it myself, but here's the info on it:
http://avidemux.org/smif/index.php/topic,17581.msg79780.html#msg79780Do or do not. There is no "try." - Yoda -
Wow...really...ok thanks for the info. Problem is I have the Logitech keyboard and it page up/dn in that is a combination of 2-3 keys and very iffy
Too bad developers of great software become so opinionated in time like google
Why cant they let users change the settings as in MPC -
That's why I like software like Aegisub and GIMP, where they set the default keyboard shortcuts, but they make it easy to change them or add your own.
Some of the default shortcuts correspond to functions I never use, so I've remapped them to functions that I DO use (like assigning Shift+Ctrl+C for "Color to Alpha" in GIMP), whereas other functions — like "Open Video" in Aegisub — didn't have a default shortcut, but I use the function a lot, so I added Ctrl+Alt+O for that one.Do or do not. There is no "try." - Yoda -
No, it's for editing subtitles. SolveigMM Video Splitter has single button shorts for start and end (M, N keys) but switching from a software you seem otherwise happy with just because of the buttons seems crazy. If you can't edit the source and compile yourself there must be some way to make a custom keyboard mapping, right? I'm too lazy to google it myself...
It may sound crazy, I agree but I was used to a single-button marker setting, not 3-buttons
I will try out the link you sent but I am trying to get at what the last version of AviDemux was that had the [ and ] markers and pretty sure I may go back to it having unsucessfully many tried other editors.
I checked out the earlier link from awgie but the poster there admitted it was complicated.
I will look for custom kyb mapper in the meantime...I was thinking about it, then forgot, thanks for reviving the thought ! -
I believe the latest version with the [ and ] keyboard shortcuts was 2.6.12
Avidemux: The beginning frame is not a key frame. Please move the A marker
By devilcoelhodog in forum EditingReplies: 13Last Post: 8th Jun 2015, 12:38 -
Curtis DVD1041 hack no longer works
By majormulatto in forum DVD & Blu-ray PlayersReplies: 6Last Post: 8th Feb 2015, 14:44 -
VOB2MPG No Longer Works - Xenocode Virtual Appliance Runtime Error
By RonnieJP in forum SVCD2DVD & VOB2MPGReplies: 2Last Post: 2nd Dec 2013, 18:38 -
*HELP* Amazon unbox DRM removal process no longer works!
By scalon2 in forum Video Streaming DownloadingReplies: 2Last Post: 24th Sep 2013, 06:50 -
Updated vidcoder no longer works
By jerecho in forum Video ConversionReplies: 4Last Post: 19th May 2013, 11:48
