The files seem to play fine so no big deal. Thanks.
Results 31 to 60 of 63
Sneaker I have another challenge. How do I compress the file size of an mkv converting to mp4? This is very strange, but I have an mkv file around 9GB that I am using vidcoder to convert to mp4 at a target size of 2900MB. The MKV is 1920x800 and has great playback but when I encode to mp4 the picture is very choppy/pixelated. I tried many different settings and used handbrake with no luck but I dropped the mkv onto the bat file and the mp4 played great so I'm wanting to do this but don't want a 9GB file but instead one around 2900MB.
He is responding that ffmpeg log, that you used 2013 ffmpeg version.
Make sure vidcoder does not change frame rate and also check 2pass encoding if targeting volume. Do not use 1pass ABR.
Or simply calculated bitrate to squeeze video more than 2x is not enough for that video, pixelating is a typical "symptom" for that. -
I hear you but I have been using the same settings for hundreds of mkv's I've encoded to mp4 and not only has the picture been fine but the video and audio quality playing on my 50" Panasonic Plasma going through my Yamaha receiver has been stunning in my opinion. I have tweaked the vidcoder advanced settings for high quality. Sure as hell taxes my processor.
I have a dilemma that I just noticed with the mp4 files remuxed with the second audio. When I play the file through my Apple TV 3 which is connected to my Yamaha receiver, the audio that is being played is the 2 channel pro logic audio instead of the 6 channel ac3 audio. This only happens with the files that I add the 2nd audio with by remuxing them. In regards to the mp4 files encoded with Handbrake that originate from mkv files, I never have any issues with my Yamaha receiver sensing and playing the 6 channel ac3. Does anyone know why this is happening and what I can do to fix it?
HandBrake creates "tref" box. While support within ffmpeg does seem to exist I don't know if it's possible to call via CLI.
I have no idea what your last reply meant. That's beyond my understanding of all this. Please explain.
Ok, so that means the only way to add a second audio to the first ac3 is to re-encode it?
I found a solution for this problem finally after looking on the web for solutions. Here is the process: First I load the .mp4 file in vidcoder and re-encode so I have a second audio (usually AAC from the ac3 5.1) and set very low quality settings to encode with so it only takes between 8-10 minutes. I then use My MP4Box GUI to demux the ac3 and aac files and the video from the original .mp4 file. I then use My MP4Box GUI to mux the video and two audio files together to make the final .mp4 file. Here is the trick: Under options you have to check Apple Friendly and Apple Friendly v2 before you mux the final .mp4. This seems to enable the Apple TV to recognize the ac3 audio and now I get Dolby Digital surround through my Yamaha receivcer. Without these options checked I have the same problem of the aac audio playing.
It doesn't seem to set tref/fall so maybe there is hope after all. MyMP4BOX GUI is just a calling mp4box so we could add it to the ffmpeg batch. Try (drag&drop files on it):
Code:@ECHO OFF PUSHD %~dp0 if [%1]==[] goto :eof :loop ffmpeg -y -i %1 -map 0:a -vn -sn -c:a aac -ac 2 "%~dpn1.aac" mp4box -ipod -add "%~1#video:name=video" -add "%~1#audio:group=1:name=AC3" -add "%~dpn1.aac:group=1:disabled:name=AAC" -new "%~dp1new_%~n1.mp4" shift if not [%1]==[] goto loop pause
Add -b:a 160k (I also added a line to auto-delete the .aac):
You don't mean manually, do you? The script should do all that automatically.Code:@ECHO OFF PUSHD %~dp0 if [%1]==[] goto :eof :loop ffmpeg -y -i %1 -map 0:a -vn -sn -c:a aac -b:a 160k -ac 2 "%~dpn1.aac" mp4box -ipod -add "%~1#video:name=video" -add "%~1#audio:group=1:name=AC3" -add "%~dpn1.aac:group=1:disabled:name=AAC" -new "%~dp1new_%~n1.mp4" del "%~dpn1.aac" shift if not [%1]==[] goto loop pause
The script did not demux and mux a new mp4. The only thing it did was create a separate AAC file.
If you put them in a different folder you either have to put that into %PATH% or adapt the script. E.g. for a subfolder "mp4box-folder":
You can also use absolute paths. (Google "absolute paths", "relative paths" and "%PATH%" for more info)Code:@ECHO OFF PUSHD %~dp0 if [%1]==[] goto :eof :loop ffmpeg -y -i %1 -map 0:a -vn -sn -c:a aac -b:a 160k -ac 2 "%~dpn1.aac" mp4box-folder\mp4box -ipod -add "%~1#video:name=video" -add "%~1#audio:group=1:name=AC3" -add "%~dpn1.aac:group=1:disabled:name=AAC" -new "%~dp1new_%~n1.mp4" del "%~dpn1.aac" shift if not [%1]==[] goto loop pause
I put everything from the gpac folder into the folder with the bat file, dropped a video file on the bat and nothing.....no AAC file anymore and no new mp4. This is too complicated for me. I don't have the time to google paths and figure all that stuff out. This script is not working with all the mp4box files in the folder anyway.
Not sure what to tell you. It's working fine here. Copy&paste any error messages/log here.
I will try it again but I am not seeing a log that is being created. Does your latest script have the command for a log?
No. Can't you read or at least copy&paste what you see in the terminal window?
Anyways, this should create two log files:
Code:@ECHO OFF PUSHD %~dp0 if [%1]==[] goto :eof :loop ffmpeg -y -i %1 -map 0:a -vn -sn -c:a aac -b:a 160k -ac 2 "%~dpn1.aac" mp4box -lf "%~nx1.log1.txt" -logs all@debug -ipod -add "%~1#video:name=video" -add "%~1#audio:group=1:name=AC3" -add "%~dpn1.aac:group=1:disabled:name=AAC" -new "%~dp1new_%~n1.mp4" > "%~nx1.log2.txt" 2>&1 del "%~dpn1.aac" shift if not [%1]==[] goto loop pause
Are you using latest mp4box? Looks like mp4 file is corrupted/invalid or mp4box bug. mp4box can't read mkv. But hopefully it is just this one file and will work for others.
But then the question would be: why would MyMP4BOX GUI work on the same file (does it?)? It is just a GUI. If you believe the file is not invalid you should report to mp4box developers.
Last resort would be remux to mp4 first but I cannot guarantee it will work:
Code:@ECHO OFF PUSHD %~dp0 if [%1]==[] goto :eof :loop ffmpeg -y -i %1 -map 0:v:0 -map 0:a:0 -map 0:a:0 -c:v copy -c:a:0 copy -c:a:1 aac -b:a:1 160k -ac:a:1 2 "%~dpn1_temp.mp4" mp4box-folder\mp4box -ipod -add "%~dpn1_temp.mp4#1:name=video" -add "%~dpn1_temp.mp4#2:group=1:name=AC3" -add "%~dpn1_temp.mp4#3:group=1:name=AAC" -new "%~dp1new_%~n1.mp4" del "%~dpn1_temp.mp4" shift if not [%1]==[] goto loop pause
Not sure why. Besides doing things in one step is there any benefit to using this script as opposed to doing this the way I described above? Occasionally, when I mux the new .mp4 the audio and video are out of sync even though in the original file they are not. In that case I use Vidcoder to add the AAC audio and no problem.
Sync should always be preserved with the script of post #58.
If you want to continue using your manual method but with keeping sync try (will only create .aac, nothing else):
No. (except maybe sync with scripts of #58 + #60)Code:@ECHO OFF PUSHD %~dp0 if [%1]==[] goto :eof :loop ffmpeg -y -i %1 -map 0:a:0 -af aresample=async=1 -c:a aac -b:a 160k -ac 2 "%~dpn1.aac" shift if not [%1]==[] goto loop pause
One last thing:
If MyMp4boxGUI works but manual does not you could look if the command it uses is different or just the mp4box version. Then adapt the script or switch the versions.
ffmpeg remux wmv to mp4
By Russs in forum Newbie / General discussionsReplies: 3Last Post: 23rd Sep 2014, 05:49 -
Remux Mp4
By danielmak in forum MacReplies: 1Last Post: 11th Sep 2014, 02:17 -
i need to remux my flv with h.264 video into mp4
By kurt770 in forum Video ConversionReplies: 8Last Post: 29th Apr 2013, 09:48 -
remux avi dx50 to mp4
By HWgeek in forum Video ConversionReplies: 20Last Post: 27th Apr 2013, 05:52 -
Remux .264 to mp4 using My MP4BoxGUI?
By Yoshi8765 in forum Newbie / General discussionsReplies: 2Last Post: 15th Apr 2012, 11:16
