I always watch movie files in limited user mode to keep my comp clean.
The checkbox for MPC restart from last position IS checked in this mode, but doesn't do jack
When I play as admin it works.
Any fix for this apart from just be admin ?
Results 1 to 16 of 16
Thanks, but I cannot toggle that nor uncheck Remember File position in limited user mode (not that I want to but just sayin).
Sorry where would I find it ? I looked under the installed dir & %(every user)%/AppData/Roaming/MPC-HC
I did delete and re-do the registry settings earlier btw (based on another thread) -
It should be in the install dir. You said you cannot toggle "Store settings in .ini file", i.e. it is greyed out. But is the box ticked or not ticked? If the box isn't ticked it means the .ini file doesn't exist.
Not in installed dir and it is not greyed out, they are just not enabled (not allowing me to change its value)
Settings.ini box is not ticked
Remember File position box is ticked but doesnt work -
I don't understand this. That's not how it should work. Either the .ini option is grayed out or you have to be able to toggle it.
To explain what I thought what the problem is: recently used files and file positions are stored in the settings. Often the .ini file is somewhere in c:\program files\... along with the mpc-hc.exe. That folder is usually not writable without admin rights so file positions aren't saved when using the .ini file. Solution would be to delete the .ini file and have MPC-HC use the registry instead. So I'd delete the .ini file and maybe all registry settings and then assume it should work. I don't know why this isn't working for you in the same way. Does not make sense to me. Or maybe you have multiple installations of MPC-HC? Something is preventing MPC-HC from writing to the registry? Hopefully someone else has an idea... -
As expected, it works as designed on another computer with limited user.
I will try another clean up. -
Yes, delete everything.
The install dir,
AppData\Roaming\Media Player Classic
HKEY_CURRENT_USER\Software\MPC-HC
HKEY_CURRENT_USER\Software\MPC-HC64
HKEY_CURRENT_USER\Software\Gabest
Also read the following. Maybe the registry permissions got messed up for some reason.
https://www.groovypost.com/howto/take-full-permissions-control-edit-protected-registry-keys/ -
Hi, so since I had to go through the whole rigmarole of settings again, I tried checking 'save to ini' and it is greyed out even in admin mode.
Is settings.ini even recommended or will it blotch things up ?
Whats the best way to export the registry settings ? -
Settings.ini is not recommended. It is mainly intended for portable use. Exporting settings should be as simple as exporting HKEY_CURRENT_USER\Software\MPC-HC using Windows' registry editor or in MPC-HC go Options>Miscellaneous>Export. (Even though I listed them I believe Gabest and MPC-HC64 are deprecated.)
Media Player Classic / MPC-BE / MPC-HC : differences between them
By devilcoelhodog in forum Software PlayingReplies: 19Last Post: 25th Jun 2017, 17:54 -
MPC-HC subtitle position not working
By sanjozko in forum Newbie / General discussionsReplies: 3Last Post: 1st May 2015, 14:36 -
Opening MPC-HC at a specific position
By mkvideo in forum Newbie / General discussionsReplies: 4Last Post: 13th Aug 2013, 16:50 -
MPC-BE: how to display datacode (PGS-Subtitle) like in MPC-HC
By flashandpan007 in forum Software PlayingReplies: 0Last Post: 29th Apr 2013, 13:14 -
Always +125% video/Frame/Zoom size MPC-HC/MPC-BE?
By tigerb in forum Newbie / General discussionsReplies: 6Last Post: 8th Mar 2013, 15:57
