  1. I have search for a while now and didn't find anything similar or maybe I didn't searched enough but I want to hardcode over 12k of mp4 files , so I wonder what is the most easy way to do it ? Is there a program or a script that can detect the mp4 file and subtitle file and hardcode multiple video files ? Like a batch script or something. But also with the possibility to set the font size and style. Even if it's a software that you now , I will buy it if it's doing the job.
    Thanks,
  2. Perhaps some more info. Like OS and format of subtitles and perhaps target codecs/container.
    At any rate: You could use a batch job with Subtitle Edit CLI to convert to .ass to have font size and style and then hardcode with ffmpeg using https://ffmpeg.org/ffmpeg-filters.html#ass
  3. I want to use on Windows 8.1 and container to be the same , with the same specification like the source file.To copy the video and audio and burn in the subtitle.
    But for exemple in a folder I have 22 mp4 files and 22 ass files.How can I burn them using a batch with ffmpeg ?
  4. You say "copy the video" and "burn in the subtitle" which makes it hard to understand because those are usually mutually exclusive. Do you want softsubbing or hardsubbing? Hardsubbing ("burn in") implies video re-encoding.
  5. I want to hardsub a video (burn in) and it mean that I need to re-encode the video it's ok , but there it must be some settings to have the same video quality like before or at least appropriate.
    Like I said in the exemple I have 22 mp4 files and 22 .ass every .mp4 and .ass file whit the same name (bla01.mp4 bla01.ass; bla02.mp4 bla02.ass etc ) and I want with a simple command to hardsub those videos and if not possible with ffmpeg on Windows , maybe is there a software that can't do exactly that.
  6. You could try something like this
    for %%g in (*.mp4) do (
    ffmpeg -i "%%g" -c:v libx264 -preset slow -crf 20 -vf ass='%%~ng.ass' -c:a copy "%%~ng_HC.mp4"
    in a batch file
    You can expand it with test of the existence of the .ass file etc.
  7. @videobruger
    Man you are awesome thanks.
    I had a problem with subtitle the first time.Than I searched a bit and found a fix to this error :
    "[Parsed_ass_0 @ 0000000001cdee60] Shaper: FriBidi 0.19.6 (SIMPLE)
    Fontconfig error: Cannot load default config file
    [Parsed_ass_0 @ 0000000001cdee60] No usable fontconfig configuration file found,
    using fallback."
    I just installed ffmpeg and then I need it to add also fonts folder into the same folder where ffmpeg.exe.
    The font config I downloaded from here : http://ftp.gnome.org/pub/gnome/binaries/win32/dependencies/fontconfig_2.8.0-2_win32.zip
  8. Try to add (before calling ffmpeg) something like this:
    @set FC_CONFIG_DIR=.\fonts
    @set FONTCONFIG_FILE=fonts.conf
    @set FONTCONFIG_PATH=.\fonts
    Also create file (text editor) 'fonts.conf'
    <?xml version="1.0"?>
    <!DOCTYPE fontconfig SYSTEM "fonts.dtd">
    <!-- /etc/fonts/fonts.conf file to configure system font access -->
    <fontconfig>
    	DO NOT EDIT THIS FILE.
    	IT WILL BE REPLACED WHEN FONTCONFIG IS UPDATED.
    	LOCAL CHANGES BELONG IN 'local.conf'.
    	The intent of this standard configuration file is to be adequate for
    	most environments.  If you have a reasonably normal environment and
    	have found problems with this configuration, they are probably
    	things that others will also want fixed.  Please submit any
    	problems to the fontconfig bugzilla system located at fontconfig.org
    	Note that the normal 'make install' procedure for fontconfig is to
    	replace any existing fonts.conf file with the new version.  Place
    	any local customizations in local.conf which this file references.
    	Keith Packard
    <!-- Font directory list -->
    	<dir>WINDOWSFONTDIR</dir>
    	<dir>~/fonts</dir>
    	<dir>.</dir>
    	<dir>~/.fonts</dir>
      Accept deprecated 'mono' alias, replacing it with 'monospace'
    	<match target="pattern">
    		<test qual="any" name="family">
    			<string>mono</string>
    		</test>
    		<edit name="family" mode="assign">
    			<string>monospace</string>
    		</edit>
    	</match>
      Accept alternate 'sans serif' spelling, replacing it with 'sans-serif'
    			<string>sans serif</string>
    		</test>
    			<string>sans-serif</string>
    		</edit>
    	</match>
      Accept deprecated 'sans' alias, replacing it with 'sans-serif'
    			<string>sans</string>
    		</test>
    		</edit>
    	</match>
      Load local system customization file
    	<include ignore_missing="yes">conf.d</include>
    <!-- Font cache directory list -->
    	<cachedir>WINDOWSTEMPDIR_FONTCONFIG_CACHE</cachedir>
    	<cachedir>~/.fontconfig</cachedir>
    	<config>
      These are the default Unicode chars that are expected to be blank
      in fonts.  All other blank chars are assumed to be broken and
      won't appear in the resulting charsets
    		<blank>
    			<int>0x0020</int>	<!-- SPACE -->
    			<int>0x00A0</int>	<!-- NO-BREAK SPACE -->
    			<int>0x00AD</int>	<!-- SOFT HYPHEN -->
    			<int>0x034F</int>	<!-- COMBINING GRAPHEME JOINER -->
    			<int>0x0600</int>	<!-- ARABIC NUMBER SIGN -->
    			<int>0x0601</int>	<!-- ARABIC SIGN SANAH -->
    			<int>0x0602</int>	<!-- ARABIC FOOTNOTE MARKER -->
    			<int>0x0603</int>	<!-- ARABIC SIGN SAFHA -->
    			<int>0x06DD</int>	<!-- ARABIC END OF AYAH -->
    			<int>0x070F</int>	<!-- SYRIAC ABBREVIATION MARK -->
    			<int>0x115F</int>	<!-- HANGUL CHOSEONG FILLER -->
    			<int>0x1160</int>	<!-- HANGUL JUNGSEONG FILLER -->
    			<int>0x1680</int>	<!-- OGHAM SPACE MARK -->
    			<int>0x17B4</int>	<!-- KHMER VOWEL INHERENT AQ -->
    			<int>0x17B5</int>	<!-- KHMER VOWEL INHERENT AA -->
    			<int>0x180E</int>	<!-- MONGOLIAN VOWEL SEPARATOR -->
    			<int>0x2000</int>	<!-- EN QUAD -->
    			<int>0x2001</int>	<!-- EM QUAD -->
    			<int>0x2002</int>	<!-- EN SPACE -->
    			<int>0x2003</int>	<!-- EM SPACE -->
    			<int>0x2004</int>	<!-- THREE-PER-EM SPACE -->
    			<int>0x2005</int>	<!-- FOUR-PER-EM SPACE -->
    			<int>0x2006</int>	<!-- SIX-PER-EM SPACE -->
    			<int>0x2007</int>	<!-- FIGURE SPACE -->
    			<int>0x2008</int>	<!-- PUNCTUATION SPACE -->
    			<int>0x2009</int>	<!-- THIN SPACE -->
    			<int>0x200A</int>	<!-- HAIR SPACE -->
    			<int>0x200B</int>	<!-- ZERO WIDTH SPACE -->
    			<int>0x200C</int>	<!-- ZERO WIDTH NON-JOINER -->
    			<int>0x200D</int>	<!-- ZERO WIDTH JOINER -->
    			<int>0x200E</int>	<!-- LEFT-TO-RIGHT MARK -->
    			<int>0x200F</int>	<!-- RIGHT-TO-LEFT MARK -->
    			<int>0x2028</int>	<!-- LINE SEPARATOR -->
    			<int>0x2029</int>	<!-- PARAGRAPH SEPARATOR -->
    			<int>0x202A</int>	<!-- LEFT-TO-RIGHT EMBEDDING -->
    			<int>0x202B</int>	<!-- RIGHT-TO-LEFT EMBEDDING -->
    			<int>0x202C</int>	<!-- POP DIRECTIONAL FORMATTING -->
    			<int>0x202D</int>	<!-- LEFT-TO-RIGHT OVERRIDE -->
    			<int>0x202E</int>	<!-- RIGHT-TO-LEFT OVERRIDE -->
    			<int>0x202F</int>	<!-- NARROW NO-BREAK SPACE -->
    			<int>0x205F</int>	<!-- MEDIUM MATHEMATICAL SPACE -->
    			<int>0x2060</int>	<!-- WORD JOINER -->
    			<int>0x2061</int>	<!-- FUNCTION APPLICATION -->
    			<int>0x2062</int>	<!-- INVISIBLE TIMES -->
    			<int>0x2063</int>	<!-- INVISIBLE SEPARATOR -->
    			<int>0x206A</int>	<!-- INHIBIT SYMMETRIC SWAPPING -->
    			<int>0x206B</int>	<!-- ACTIVATE SYMMETRIC SWAPPING -->
    			<int>0x206C</int>	<!-- INHIBIT ARABIC FORM SHAPING -->
    			<int>0x206D</int>	<!-- ACTIVATE ARABIC FORM SHAPING -->
    			<int>0x206E</int>	<!-- NATIONAL DIGIT SHAPES -->
    			<int>0x206F</int>	<!-- NOMINAL DIGIT SHAPES -->
    			<int>0x2800</int>	<!-- BRAILLE PATTERN BLANK -->
    			<int>0x3000</int>	<!-- IDEOGRAPHIC SPACE -->
    			<int>0x3164</int>	<!-- HANGUL FILLER -->
    			<int>0xFEFF</int>	<!-- ZERO WIDTH NO-BREAK SPACE -->
    			<int>0xFFA0</int>	<!-- HALFWIDTH HANGUL FILLER -->
    			<int>0xFFF9</int>	<!-- INTERLINEAR ANNOTATION ANCHOR -->
    			<int>0xFFFA</int>	<!-- INTERLINEAR ANNOTATION SEPARATOR -->
    			<int>0xFFFB</int>	<!-- INTERLINEAR ANNOTATION TERMINATOR -->
    		</blank>
      Rescan configuration every 30 seconds when FcFontSetList is called
    		<rescan>
    			<int>30</int>
    		</rescan>
    	</config>
    </fontconfig>
    Anyway problems with fontconfig and ffmpeg are common and i would advise explicitly load font (file located side to ffmpeg.exe) .
