Results 1 to 22 of 22
  1. Hi, please can you help a c*t?
    I have 2 video .avi files:
    one is an uncompressed interlaced video file https://dl.dropboxusercontent.com/u/39871584/INTERLACE.AVI
    and one is uncompressed progressive video file https://dl.dropboxusercontent.com/u/39871584/PROGRESSIVE.AVI
    MediaInfo correctly recognize the interlaced one as interlaced, and the progressive one as progressive.
    But now I wonder: using the HEX editor, can I modify a flag of the progressive one so that it is recognized as interlaced?
  2. See the ODML extensions, the vprp chunk.
    http://abcavi.kibi.ru/docs/odml1.pdf
    Example analysis from your interlaced file:
    76 70 72 70 header fourcc          "vprp"
    64 00 00 00 size                   100 bytes
    00 00 00 00 VideoFormatToken       0=UNKNOW
    01 00 00 00 VideoStandard          1=STANDARD_PAL
    32 00 00 00 dwVerticalRefreshRate  50
    80 07 00 00 dwHTotalInT            1920
    38 04 00 00 dwVTotalInLines        1080
    03 00 04 00 dwFrameAspectRatio     3:4 ???
    80 07 00 00 dwFrameWidthInPixels   1920
    38 04 00 00 dwFrameHeightInLines   1080
    02 00 00 00 nbFieldPerFrame        2
    FieldInfo[0]
    20 02 00 00 CompressedBMHeight     544
    80 07 00 00 CompressedBMWidth      1920
    1c 02 00 00 ValidBMHeight          540
    80 07 00 00 ValidBMWidth           1920
    00 00 00 00 ValidBMXOffset         0
    00 00 00 00 ValidBMYOffset         0
    7a 00 00 00 VideoXOffsetInT        122
    18 00 00 00 VideoYValidStartLine   24
    FieldInfo[1]
    50 01 00 00 VideoYValidStartLine   336
    You can make MediaInfo report the progressive video as interlaced simply by changing the nbFieldPerFrame from 1 to 2. But that doesn't make the video interlaced and the video data will be laid out wrong (not over/under format). Any program that really uses the vprop information will get confused. To do it properly you'll need to change other values in the vprp header and separate the fields within the video chunks.
  3. Originally Posted by jagabo View Post
    FieldInfo[0]
    FieldInfo[1]
    please jagabo wich program are you using to achieve this informations?
  4. I did a simple hex dump and made the notes myself in Notepad.
  5. but I need to understand:
    for example the string "544" is traduced is 20 02 00 00 ?
    the string "1920" is "80 07 00 00" ?
    but for example 80 07 00 00 is a hexadecimal value?
    and for example 720 and 576 what correspond to?
  6. Originally Posted by marcorocchini View Post
    Intel processors are little endian. So you need to reverse the order of the bytes. 80 07 00 00 --> 00 00 07 80 --> 00000780 --> 780. Use a hex calculator to convert from hex to decimal. Windows' built in calculator has a Programmer mode that has hex/decimal conversion. 780 hex is 1920 decimal.
  7. Code:
    please jagabo I would set this aspect ratio to 16:9 (par 16:9?) in this case what is the values correct to put in place of 03 00 04 00?
  8. Use a hex calculator or table.
    dec hex
     0   0
     1   1
     2   2
     3   3
     4   4
     5   5
     6   6
     7   7
     8   8
     9   9
    10   A
    11   B
    12   C
    13   D
    14   E
    15   F
  9. Why don't you just read the documentation, experiment, and figure it out for yourself. Here's a hint:
    word = 2 byte value
    dword = 4 byte value
    Since AVI is a native Microsoft format, Microsoft has usually used Intel processors, and Intel processors are always little endian, multibyte values are stored least significant byte first, most significant byte last. So the two byte (word) hex value 1234 is stored in memory as 34 12. The four byte (dword) hex value 12345678 is stored in memory as 78 56 34 12.
    http://www.ascii.cl/conversion.htm
  10. oh my cat
  11. my pow cannot press key in the numpad
  12. please help a c**
  13. Just put in different numbers and see how it effect playback of the video.
  14. * my paw
  15. Then even if I give you the numbers you won't be able to type them in.
  16. mmm but I'm able with mouse and copy and paste
  17. Then copy and paste from the hex chart I linked to.
  18. Jagabo please help me: considerting this mjpeg interlace video file:
    https://dl.dropboxusercontent.com/u/39871584/mjpegInterlace.avi
    And this mjpeg progressive video file:
    https://dl.dropboxusercontent.com/u/39871584/mjpegProgressive.avi
    can you tell me where is the flags internally the files that tell to mediainfo that they are interlaced/progressive?
    this mjpeg .avi don't have the vprp section
    thanks
  19. It's in Mainconcept's private AVI1 chunk, the first byte is a 01 instead of 00. Each frame has an AVI1 chunk. Changing the first one (at address FE12) will cause MediaInfo to report the video as interlaced. But it may not be decoded properly, depending on what MJPG decoder is used (ffmpeg and lsmash return a picture that looks ok, PicVideo's MJPEG decoder doesn't). And, of course, even if the decoder decompresses the video, it will not be interlaced.
  20. Ah interesting, Jagabo please help me cat:
    this time consider this small avi from FFMPEG in mjpeg:
    https://dl.dropboxusercontent.com/u/39871584/mjpegFFmpeg.avi
    mediainfo see it as progressive, is there a way to "force" it to see as interlaced?
  21. That has a vprp chunk but it only has one FieldInfo structure in that chunk. Changing the nbFieldPerFrame value to 2 doesn't cause MediaInfo to report it as interlaced -- though it doesn't report progressive either. Presumably because there is now a discrepancy between the the nbFieldPerFrame value and the number of FieldInfo structures.
