HI,
I get a error in virtual dub what can ik do about it becaus .
the requested audio compression is not compatible with the input format. check that the sampling rate and channel count of the input match those of requested fromat.
what must i do nou pleas some help
when i not solve this problem i can not us tmpegenc olso not becaus tempegenc onlie sie the video file and no soud.
so what kan i do in vitual dub to get is beter.
greatings and thanks
vlagzalmer
Set the audio to 'direct stream copy' or otherwise set no audio compression in the Virtualdub audio settings before you save/frame serve.
May also be a good idea to check the file information (from the File menu) to make sure your file has valid audio in it. As far as I know, audio the compressions available on Virtualdub should work with PCM audio at any sample rate...if it's not PCM (eg if it is MP3 or something), that could be your problem. (It could be helpful to know what your source and settings are)
VirtualDub Error
By WebMaximus in forum Video ConversionReplies: 5Last Post: 6th Jun 2011, 13:29 -
What is this error mean? (VirtualDub)
By UMO in forum Newbie / General discussionsReplies: 1Last Post: 27th Apr 2010, 12:19 -
VirtualDub Error Message - Video Compression Error
By HartsVideo in forum DVD RippingReplies: 19Last Post: 7th Jun 2009, 20:18 -
Error with Xvid4PSP when converting MKV to AVI (VirtualDub Error)
By Peter25 in forum Newbie / General discussionsReplies: 1Last Post: 9th Apr 2009, 18:10 -
VirtualDub error
By WebMaximus in forum Newbie / General discussionsReplies: 22Last Post: 6th Aug 2008, 01:55
