normally i convert my cd flacs to mp3 using foobar's defaults for V0.
it uses the command ' -S --noreplaygain -V 0 - %d '
is there a better way for 24bit vinyl flacs, or am i good to go with that one? what about cvbr256 aac?
Use flac - for lossy compression your question is irrelevant - btw 192kHz sample rate is not supported by mp3 (max 48kHz), aac support up to 96kHz sample rates.
it's 96khz, sorry. how is it irrelevant. i want to convert it for better compatibility
If your player is capable to play 96kHz then aac seem to be only one available option for you.
It is irrelevant as lossy compression mean loosing fine details - practically everything bellow -100dBFS will be removed form signal.
Compatibility is limited by your player capabilities - aac is sufficiently mature audio codec so seem to be reasonable selection.
M3U8 extentions to Mp3 or AAC
By habboubih in forum Video Streaming DownloadingReplies: 2Last Post: 24th Nov 2015, 23:25 -
Retain volume when converting 5.1ch aac to mp3
By zetsu_shoren in forum AudioReplies: 20Last Post: 26th Apr 2014, 06:25 -
MP3 to AAC while keeping Abum Cover Art
By duff916 in forum AudioReplies: 13Last Post: 21st Mar 2014, 03:03 -
How to convert .mkv movies aac or mp4a soundtrack to mp3 ?
By winter snake in forum Video ConversionReplies: 16Last Post: 11th Feb 2013, 17:38 -
Transcoding AAC to either AC-3 or MP3
By DRP in forum AudioReplies: 2Last Post: 16th Aug 2012, 12:41
