Yeah I have it going for some time now. Just a pain setting up. I use 2 authoring programs depending how I feel that particular day (LOL). I use TMPGEnc Authoring Works and MultiAVCHD. Sometimes I use both on the same project. Every once in a while MultiAVCHD will throw the audio out of synch. I have no idea why. So when that happens I create bluray files in TMPGEnc, then drop those files in MultiAVCHD and wall-ah everything is lovely.
Results 31 to 34 of 34
TMPGEnc Authoring Works is basic and easy to use. It is pretty straight-forward. Load your files, then a window pops up that allows you to immediately set chapter points. I believe you can edit out portions of the loaded clip in that load pop up window, which I never use. You can add your own menu backgrounds and set up you Bluray pop-up menu. You can add audio in your menu but for it to work right it should be embedded in your background picture. So there is a bit of customization, not a lot. Like everything there is some trial and error, but it is menu driven. If you screwed up something it will let you know in a menu called I believe DEMO.
I have found it to be 100% reliable and my go-to when multiAVCHD acts funky or crashes. It has never crashed or caused any headaches and I have used it quite a bit. When I want to use a particular functionality that MultiAVCHD has, but keeps crashing, I use the same clips in TMPGEnc to create bluray files then import those files in MultiAVCHD and that ALWAYS works. MultiAVCHD can be very tempermental.Last edited by DVWannaB; 9th Mar 2017 at 14:53.
VHS Capture with Hauppauge HD PVR2 (No Color or Stereo Audio)
By renarayne in forum Capturing and VCRReplies: 8Last Post: 22nd Sep 2019, 17:06 -
Hauppauge PVR2 - audio sync issue with Hauppauge Capture -- alternative?
By texas1 in forum Capturing and VCRReplies: 35Last Post: 2nd Apr 2017, 03:27 -
Can AVCHD Be Burned To Blu-Ray Instead of DVD?
By LenC327 in forum Authoring (Blu-ray)Replies: 3Last Post: 9th May 2015, 06:06 -
Blu-ray rip to m2ts
By DrReaper in forum Blu-ray RippingReplies: 16Last Post: 11th Feb 2015, 19:34 -
Blu-ray/AVCHD/M2TS Encoding Bit rate Chart
By DrDeceit in forum Video ConversionReplies: 3Last Post: 21st Nov 2012, 07:24
