I have successfully ripped all other VOBs from 4 DVDs and edited into 1 MP4 file. It's a sporting game. The last VOB on disc 4 is highlights of the game. It is very stubborn to copy cleanly; rips real fast but the file always stutters and shows its runtime at 2 plus minutes (it's 11 minutes). The disc is scratch free. Can copy the other files no problems?
edit to add it plays smoothly in set top player and on the computer just fine.
What do you copy with? Just windows explorer?
You could try the old dvddecrypter and see if can copy everything. -
Hi Baldrick! I remember you from the mid 2000s.
DVD Decrypter
Smart Ripper
Windows 10
All copy very fast since the VOB is only 780-ish mb wise. Very odd. Should I let DVDDecrypter copy the whole disc? I'll give it a try. -
It did not. I see the problem now. There was 2 chapters in the 11 min file. Part 1 of the VOB is inside the first chain of VTS_01_4 and VTS_02_1 is screwed up in there somehow.
*Edit. Problem solved. Copied the VOB file once again to the desktop. Opened in VideoRedo and converted to MP4 instead of having VideoRedo doing a quickstream fix first.Last edited by tom z; 7th Mar 2017 at 13:12.
VOB files won't play audio after copying / ripping to harddrive.
By guy24s in forum DVD RippingReplies: 7Last Post: 16th Apr 2015, 05:15 -
Blu ray copying problem
By sanzo778 in forum Blu-ray RippingReplies: 6Last Post: 27th May 2014, 01:57 -
Subtitle problem when copying DVD
By zworg2 in forum Newbie / General discussionsReplies: 8Last Post: 30th Sep 2013, 14:26 -
Homemade BluRay not converting to DVD
By madmaxmarchhare in forum Video ConversionReplies: 21Last Post: 12th Aug 2013, 18:38 -
Copying DVD's
By ckat916 in forum Authoring (DVD)Replies: 7Last Post: 31st Jul 2012, 17:47
