Yes I did restart the PC.
I've run avsmeter with the -log.
It shows in the command prompt the same error as I was getting in virtualdub.
I'm probably being thick, but I can't see where the log file has been created? It's not in the folder I have avsmeter running from....
Results 31 to 40 of 40
OK whilst I was waiting for a reply, I continued googling, and found a QTGMC download with required dlls.
I have copied MT_Masktools-26.dll to the folder, and now I get a different error msg:
Evaluate: System exception - Access Violation
(QTGMC.avsi , line 918)
(QTGMC.avsi, line 473)
I am guessing this may mean I've found the file I'm looking for, but possibly the wrong version...? -
Try hello_hello's zip with all the plugins here:
https://forum.videohelp.com/threads/383321-How-to-load-QTGMC-for-use-with-megui#post2484787 -
That's a lot of plugins...!
Shame there's not an easy way to just extract them all to the plugins folder.
I think I've done them all, but there was no mt_masktools.dll in there.
I put that back in from my previous attempt and still get the same access violation message.
Is it possible for someone to just give me a zip of their plugins folder or is that against the rules?
Another question is, could the clip I'm using be causing the issue?
*EDIT to add* I haven't done anything with the fftw folder as I haven't a clue what that's about! -
Right I'm going to bed (another later night that hasn't got me anywhere
Thanks everyone for the help so far. I fought shy of avisynth for years fearing this exact issue. I just want something that works! lol
I'll persevere for another day or so, as I really want this to work, but likewise I do not have endless amount of spare time...!
Any other suggestions welcomed!
Nick -
Just try hello_hello's collection of everything you need. Replace everything you might have already with his versions, including the QTGMC.avsi.
Yes, it's infuriating and frustrating and makes you feel stupid.
But, it's worth it in the end. And you've begun with one of the most difficult filters to get working in all of AviSynth. After getting this one going, anything else will be a breeze (well, almost everything). But, again, it'll be worth it. About all I work with is field-blended garbage and without QTGMC and SRestore I'd be completely lost. And if, after all this, you still can't get QTGMC to work, we can point you to bobbers nearly as good and much easier to get going. -
OK I'll have another go later, stripping it all back and starting again.
I'm not sure about the fftw folder though. It's talking about making libraries or something and I really haven't a clue about that. Can I ignore that folder or do Ineed to work through that aswell? -
I'm sorry I misread it (blame my tiredness!)
I've now done it and can see from the results what was wrong. I installed the 64 bit version of the C++ package (thinking it was linked to Windows version).
Now I've installed the 32-bit both the QTGMC and SRestore functions are working
Thanks everyone for your help!
Is it true all PAL VCRs can play NTSC, PAL, SECAM tapes?
By digicube in forum Capturing and VCRReplies: 26Last Post: 16th Sep 2017, 10:20 -
Creating VFR encodes from NTSC animation DVD
By ChewieLewis in forum Video ConversionReplies: 10Last Post: 8th Jan 2017, 17:18 -
help needed Ntsc(PAL) dvd to Ntsc
By spiritgumm in forum Video ConversionReplies: 19Last Post: 23rd Nov 2015, 18:19 -
Live Action & Animation combination; duplicate frames and jagged lines
By Rugratskid in forum DVD RippingReplies: 4Last Post: 10th Aug 2015, 20:41 -
Pls help! Best way to convert NTSC VHS (captured using PAL VCR) to NTSC DVD
By rairjordan in forum Capturing and VCRReplies: 33Last Post: 28th Nov 2013, 11:33
