Hi, I'm trying to make some small and easy filters for VirtualDub but I'm not finding any documentation on how to compile .vdf files nor which language should I use, etc.
I've got experience programming a few languages, Java, PHP, JavaScipt, a bit of ActionScript and maybe a few other things for smaller projects, but trying to look at a Source Code of a filter I found on the internet was a bit of a mess, specially since it's been a while since the last time I've been programming.
Any help, explanations, links to documentations or sample codes would be great !
If you want to get started, get the plugin sdk: http://www.virtualdub.org/filtersdk.html
Also find emilliano ferrari filters pack source, these filters are very simple (good for beginner).
Btw language is c++. -
Thanks ! Found the SDK shortly after posting but guessed people would answer more if I didn't say it haha.
Either way thanks for the suggestion, I'm going to look at those filters, since I've never done C++ looking at same easy samples will fasten a lot the learning. Hope this be enough
DVD Creation
By mojavesam in forum Newbie / General discussionsReplies: 4Last Post: 8th Apr 2015, 13:15 -
New to video creation
By Sarahbokbok in forum Newbie / General discussionsReplies: 12Last Post: 4th Jan 2015, 12:25 -
need help with ffmpeg and thumbnail creation
By adom in forum EditingReplies: 3Last Post: 8th Jul 2014, 06:30 -
Automatic chapter creation
By medwatt in forum Newbie / General discussionsReplies: 6Last Post: 4th Jun 2014, 20:41 -
Viruses creation in 2013
By ranchhand in forum Off topicReplies: 0Last Post: 19th Mar 2014, 06:15
