Hi everybody,
I got some AVIs with VirtualDub from my comcorder in 720x480 (huffyuv codec). Also I have a Gradiente D22 player and it has some limitations. It plays almost anything if I burned the CD in SVCD mode but the mpeg may be a MPEG1 or MPEG2 in any resolution. Also it only handles about 2500 kbps max.
I did a lot of test and Im not been able to decide what would be the best I could get with this player. For example, I could go with a standard SVCD, but I didnt think its so good as a MPEG1 with about 2500 kbps (xVCD). Maybe I didnt chose the right things in TMPGEnc... I dont care how much space It will use, I think 30 minutes in a CD would be enough.
So, what you all suggest?
[]'s
You want quality? The answer is CCE + SVCD. With only 30 minutes on one CD, you can get near-DVD quality.
And with very careful setup you can fit 45 mins to a CD. If you don't mind letterboxing then 60mins....
If your player only handles 2500 kbps and your video clip is 30 minutes, you can't fill the CD completely. CBR @ 2500 and standard SVCD resolution should be ok. If you use a higher resolution, there will be some macroblocks at that bitrate.
Best quality DVD output software for maintaining photo quality
By P_Erickson in forum Newbie / General discussionsReplies: 20Last Post: 21st Apr 2012, 22:30 -
best audio video quality of youtube poor quality and not hq flv videos.
By nusratjaveid in forum Video ConversionReplies: 3Last Post: 20th Jun 2010, 19:23 -
3 AVIs to DVD low quality or medium quality to drive then DVDshrink?
By johnharlin in forum Video ConversionReplies: 5Last Post: 4th Apr 2009, 02:18 -
lower low quality online tv how to high quality :( :x
By gorry563 in forum Video Streaming DownloadingReplies: 1Last Post: 22nd Feb 2009, 06:56 -
&fmt=18 does not give the same quality as playing by "high quality
By arminio in forum Video Streaming DownloadingReplies: 2Last Post: 9th Feb 2009, 18:33
