Hello fellas. Need some advice again. Does anybody know settings in VLC player for iOS so that I can zoom thisto look like this
Thanks in advance.
Sent from my iPhone 6+ using Tapatalk
First and foremost, I would turn the screen 90 degrees.
Otherwise, from the little information that I can find, I'm not sure that it's supported.
In any case, VLC has it's own forums where you will likely get a faster response: https://forum.videolan.org/viewforum.php?f=36Last edited by Krispy Kritter; 4th Mar 2017 at 15:08.
Google is your Friend -
On Android you can use use VLC's "fit" control and select Fit Vertical. I would guess the iOS version has the same.
VLC Player Zoom Problem
By bitrape in forum Software PlayingReplies: 0Last Post: 8th Feb 2017, 17:20 -
vlc for ios will not play mkv with ac3 audio
By asdffdsa in forum Newbie / General discussionsReplies: 4Last Post: 23rd Feb 2016, 11:40 -
Pan Crop Zoom Vegas
By Compo in forum EditingReplies: 5Last Post: 30th Apr 2013, 05:29 -
Zoom and/or Crop?
By captainzog in forum Newbie / General discussionsReplies: 11Last Post: 10th Apr 2013, 13:04 -
Video conversion on iOS??? (like ffmpeg for iOS???)
By shawntop in forum Video ConversionReplies: 8Last Post: 2nd Apr 2012, 12:57
