I'm not sure if it's my specs or something else, but this lag is really getting annoying. This is the first time it's happened for me. It's not just pp either, mpc, vlc, kmp, 5kp, gop, etc. either freeze, lag or crash when i try to play these files. below are my specs:
Processor
Intel(R) Core(TM) i7-5500U CPU @ 2.40GHz
Video Card
AMD Radeon R7 M260
Video Card #2
Intel(R) HD Graphics 5500
RAM
8.0 GB
Operating System
Microsoft Windows 10 (build 14393), 64-bit
i have the klite codec pack, i use the lav, i turned off dvxa codecs, i tried changing the refresh rate on my monitor but nothing. any clue as to what it could be? thanks.
Post MediaInfo logs of the files. If you are trying to play high bitrate / 4Kp60 or similar your PC is simply too slow. If it's not that try switching between "none" and "DXVA2 (copy-back)" in the LAV Video hardware settings. But Broadwell only has hybrid HEVC and limited to 8 bit at that. And your old AMD card has no HEVC decoding at all. I recommend MPC-HC / LAV 64 bit for fast software decoding of HEVC.
oh shit lol. i was worried my graphic card was too old ;;
attached is a log of my file. ill try the solutions you offered tho -
That video is AVC, not HEVC. And only 1920x800 resolution at 24 Hz. Your PC should be able to handle it without breaking a sweat.
Try updating/reinstalling the GPU drivers. Check that neither CPU nor GPU are clocking down and/or overheating (GPU-Z, CoreTemp/CPU-Z). Restart the PC. Check Task Manager for any background processes eating up all CPU/RAM or HDD I/O.
PotPlayer - 1080p lag
By jackuars in forum Software PlayingReplies: 10Last Post: 10th Apr 2016, 15:39 -
POTPLAYER - lag when seeking
By skribby in forum Software PlayingReplies: 9Last Post: 9th Aug 2015, 17:09 -
(Solved) Problems playing mkvs with vlc media player
By Wizard23 in forum Software PlayingReplies: 4Last Post: 27th Sep 2014, 12:32 -
Need no lag capture card to play xbox one on my pc with no lag
By joeyiswhammo in forum Capturing and VCRReplies: 6Last Post: 31st Aug 2014, 10:41 -
Playing within a folders PotPlayer
By cybersa in forum Software PlayingReplies: 2Last Post: 25th Apr 2014, 13:20
