I'm trying to capture a tape which I believe is in the PAL format.
I have 2 VCRs.
Panasonic NV-HS620AM - claims to playback NTSC/PAL/MESECAM as well as SECAM-D/K
Panasonic NV-HS860 - says it plays MESECAM
When I play the tape back in the 620, I get a black and white image. When I play the tape back in the NV-HS860, I get a black and white image however there is a weird rainbow color pattern in the picture. See attachment.
Could this be a case of MESECAM being recorded on the tape and its color subcarrier is corrupted? I tried capturing this with a Canopus ADVC-110 as well as with a SkyHD CaptureX card which seems to accept any input format. I tried choosing all the different PAL and SECAM formats yet nothing seemed to work.
It's also an OLD tape. Every car I recognize in that video is a mint condition 70's American car.
Yeah, it's most likely from the 80s I believe. Any ideas? Is it most likely a weak colorburst on the tape, so I'm stuck with black and white?
Without knowing exactly what format the tape is it's all guesswork.
If you have a PAL television, even if the tape is NTSC....it should still show up(on the TV) in color.
Most capturing software/hardware will show B&W.
Avidemux color issue
By Akai-Shuichi in forum RestorationReplies: 4Last Post: 16th Jan 2017, 22:56 -
MPC color issue
By mlmiller707 in forum Software PlayingReplies: 12Last Post: 28th Nov 2015, 13:43 -
Sony Hi8mm tape issue
By schematic2 in forum Capturing and VCRReplies: 3Last Post: 3rd Apr 2014, 14:18 -
PAL LP VHS Tape - "Missing" colors during capture
By FrankDrebin in forum Capturing and VCRReplies: 6Last Post: 15th Aug 2013, 12:26 -
Multi-System VCRs; PAL N tape, PAL VCR
By darito in forum Capturing and VCRReplies: 14Last Post: 17th Apr 2012, 12:54
