Hello Everyone,
One question about Dolby Digital Plus stream.
When you use MakeMkv you can decide to extract DD from DDplus.
When you check the DD stream, the bitrate is 640Kbps (maximum bitrate for DD so it's perfect).
When I check m2ts files from bluray DDplus bitrate is 896Kbps and core is only 512Kbps ?
So my question :
Is makemkv extract the core and set a bitrate to 640Kbps (so quality is only 512Kpbs) ?
Or makemkv convert (but it should take time/cpu) DDplus to DD ?
Other software like eac3to extract the core at the 512Kbps bitrate...
Results 1 to 1 of 1
Dolby Digital: effects of reducing bitrate.
By ziggy1971 in forum AudioReplies: 9Last Post: 22nd Apr 2016, 02:11 -
What's the deal with Dolby TrueHD/AC3 Core?
By Starburst in forum Newbie / General discussionsReplies: 27Last Post: 17th Sep 2015, 09:36 -
Which do you prefer - Dolby Digital or DTS?
By yoda313 in forum PollsReplies: 48Last Post: 17th Apr 2014, 22:49 -
Dolby Digital Plus issue - AC3 instead of E-AC-3 in MKV file
By psychoboust in forum AudioReplies: 9Last Post: 20th Jan 2014, 07:08 -
flac in mkv not playing as dolby digital
By MalayZN in forum AudioReplies: 4Last Post: 4th Feb 2013, 01:44
