Results 1 to 11 of 11
  1. Recent acquired a used SONY SL-HF900 and it has problems playing prerecorded tapes; lots of static at the bottom of the video. I have attached example video.
    The prerecorded tape plays fine on another Betamax VCR, so it must be my SONY SL-HF900. I think the video heads maybe dying or I may have alignment issues.
    Home recordings made on this machine doesn't have this problem but on occasions streaks will appear on the video.
  2. Member DB83's Avatar
    Jul 2007
    I have not downloaded your clip although mega.nz is AFAIK clean.
    But for < 14 meg why not just post it as an attachment here ?
    Aug 2010
    San Francisco, California
    The noise is cyclical so my guess is an alignment problem with a rotating part in the tape path (other than the drum).
  4. Originally Posted by DB83 View Post
    Videohelp reported invalid file format. It doesn't support m4v. I guess I can change it to mp4.
    Feb 2006
    Since the unit is used, it probably wouldn't hurt to have it serviced.
  6. Originally Posted by october262 View Post
    Nah, I got it for $50. I'm not gonna spend $200 to service it. I'll live with it or find some DIY tutorials.
  7. Member DB83's Avatar
    Jul 2007
    Well since I mentioned it, I now downloaded the attachment.
    I am no expert here but if self-recorded tapes do not exhibit this issue then I can not see it being an alignment issue.
    My own take would be severe tracking - are these commercial tapes SP since I have seen such tapes as LP. And are you certain they are genuine tapes and not fakes. ?
    I once obtained a tape from the US which was only available as NTSC. However it played/ captured as a PAL with no PAL60 ie B&W characteristics.
  8. These are genuine commercial BII tapes. BI=SP, BII=LP, BIII=EP. Most prerecorded commercial Beta tapes are BII I think.
    Aug 2010
    If it records out of alignment, it plays back in the same erroneous alignment — and looks okay.
  10. Member DB83's Avatar
    Jul 2007
    ^^ Ok. So you assume that the 'aligment' issue compensates itself at playback.
    Of course anyone, in this scenario, with a vcr that has issues would only see those issues when playing back on another vcr - the issue would manifest itself on vhs as well.
    More so that a seller can rightfully claim that the vcr is in good working order even if that is not the case.
  11. Just made a home recording with a digital betacam tape. the quality was tiny bit better than a high grade betamax tape.
    I was told not to use betacam metal tapes because it can damage the video heads. is this true?
